Question about Olympus Camedia C-740 Ultra Zoom Digital Camera
Auto Focus Problem
I have a new problem with my C-740. The auto focus takes 2-3 seconds to lock before the shutter snaps. By that time, I've lost the shot. I'm wondering whether I set something wrong or if the camera is malfunctioning. Any help would be appreciated.
    Master:
  • 852 Answers
There are numerous reason why this camera could be haveing lazy focusing. The C-7xx series do not have focus assistance, the focus by contrast. So if there item you are focusing does not have alot of contrast to it, the camera will search for a while to find something. In darker areas such as indoors, low light, or low contrasty areas your Olympus will also take longer to focus due to the contrast issue. Many cameras in this price range has similar issues. For fast moveing subjects you may try using the wide angle settings on the zoom, use manual focus, or study up on Hyperfocal distance an use this method.
Posted on Sep 12, 2005
    Master:
  • 852 Answers
Way to check settings is to take the batteries out for a while, it should revert to factory default settings. I tell a lot of People to try this, it works an amazing number of times. Auto focus looks for vertical lines, what are You shooting at? Try rotating the camera 90 degrees, if it locks better,Bingo. Subjects without much contrast are hard to lock focus on
2 Suggested Answers
neta
  • 852 Answers
SOURCE: Focus Problem
Low light focus lock can be a problem with this camera. But in normal or bright light there should be no problem with auto focus lock. If this is a new problem, you should check to see if a setting has been changed. With so many options, it is easy to accidently set something that causes unusual results (been there, done that). First ... Go to the Setup Menu and see that the "All Reset" option is selected. This will cause everything to be reset to factory default each time you power-on the camera. Turn the camera off and then turn the camera on. Then take some test photos to see if your auto-focus-lock is improved. If that works, there is no need to check the items below. If that does not work, here are some control changes to try. Remember if you turn off the camera everything gets reset. That camera uses contrast detection for auto focus and it is normally set to "Multi-Area Auto Focus". Try changing it to "Spot Auto Focus" and do some tests, including with the camera set to one of the programs or manual mode. There is another setting called "Autofocus Area", you should investigate. Check your manual to determine what you can do with this control. There is another control called something like "continuous auto focus". Check the manual for further information. If none of the above help, it is time to see about some camera repairs.
Posted on Sep 06, 2005
My 100-400 mm EF canon takes too long to auto focus.I like to take pictures of flying birds and i get alot of blurred pictures even at a shutter speed of 1/3200sec. I use the #2 position on the stabilzer...
Manually pre-focus to the distance you'd expect then the auto focus won't have far to move/lock on. Only turn the IS off if you are using a tripod. The auto focus works by detecting a difference in contrast so if the conditions are not compatible i.e a BG the same as the subject it will 'hunt and peck'.
Jan 26, 2014 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
Olympys fe-270 takes blurry pictures
Try this. Aim the camera at the person/object you want to take a picture of. Press the shutter button "HALF WAY DOWN" wait 2 seconds then complete by pressing all the way down to take the picture. The auto focus works on the "half way down" stroke. Some cameras have a light that goes from red to green to let you know the focus was completed. Or, just wait the 2 or so seconds.
Dec 22, 2009 | Olympus FE-270 Digital Camera
Auto focus does not work in the creative zone
Sounds like your custom functions have been changed to work this way. On the EOS 350 D it is Custom Function #04. To change it back to default you need navigate through Canon's menus. Here's how to get there: while in one of the creative zones go to your camera menu and navigate to the 5th tab on the right. Select “Custom Functions (C. Fn)” from this tab. This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. That should get your camera back to the expected auto focus with the shutter button.
Happy shooting :-)
Feb 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have a Nikon D200 camera. It's now 2 years old and I'm having difficulty with the auto focus. The camera focuses but it comes in and out and I have to depress the shutter several times to get it clear....
the auto focus works on the basis of contrast. If you aim your chosen auto focus square at an item that fills that square with only one color or shade of color light a blank wall or a solid blue sky the camera can't focus because it is trying to compare the contrast in order to focus the camera. try to make sure that you choose an item with contrast to aim your auto focus square on like someones eye and part of their cheek so the camera can see somre contrast to evaluate then focus. Obviously you depress your shutter half way to activate the auto focus let the camera do its thing keeping the shutter half way depressed move your field of vision to where you want it then fully depress the shutter to take the picture. the camera relys on seeing some contrast within your autofocus square in order to auto focus
Jan 14, 2009 | Nikon D200 Body Only Digital Camera
Canon 17-85 Lens with Rebel XTI Camera
This is because the camera will not expose a picture until the auto focus is locked. If you are shooting in dimly lit conditions, the AF might have a hard time obtaining a lock. Using the flash as auto focus assistance many time helps in this condition.
Another reason might be that you try to focus on even surfaces with low contrast. The auto focus work by sensing contrast. Even surfaces, such as a white wall or the sky, have very little contrast, therefore the auto focus will not be able to obtain a lock. The solution here is to point the AF sensor at something with more contrast, such as an eye, a pole, or basicly anything that have edges/lines.
I hope this help you!
/Chris
Jul 09, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Nikon D40X stopped auto-focusing yesterday
I had the same problem. My issue was with all my lenses. I solved it by going to the menu and selecting the custom setting menu (pencil icon). Then from the right menu select the AE-L/AF-L and press OK. Then make sure it is set on AE/AF Lock. Presto...all my lenses worked on auto-focus.
Feb 24, 2008 | Nikon D40x Digital Camera
Better Focus
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures'). 4. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Better Focus
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Focus
Sep 11, 2005 | Toshiba Sora PDR-T30 Digital Camera
Focus Problem
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Olympus Camedia C-740 Ultra Zoom Digital Camera Logo
116 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
