Question about GoVideo Go Video DVD/VCR Combo
Dual layer/double layer dvds - copies I made
The player will not play the movies. If this one cannot, can you recommend a player that will?
    Champion:
  • 224 Answers
Depends what format your burnt files are......divx,vob,wmv,dvd ???
Posted on Sep 19, 2008
Burner continues to burn only a portion of the DVD
Some DVDs are dual layer, some are double sided, some are double sided and dual layer. You must be sure you are using the correct media and that your drive can program it. Most store-bought DVD movies are dual layer, and if you try to copy them onto a regular DVD, then you will only copy about half of the movie.
Sep 18, 2013 | EZ Dupe Ezd880 DVD Coach Desktop...
When I want to copy a CD must I only record on a CD blank disc; i.e. not a DVD
It depends upon what type of data you want to copy onto a CD or DVD.
If you want to copy and play music in a CD player then it needs to be on a CD disc.
If you want to copy and play movie DVDs in a DVD player then it needs to be on a DVD disc.
If you want to backup data files then it can be on either CD or DVD discs (depending upon the amount of data to be stored on the disc - CD holds 700 Mb, single layer DVD holds 4.7 Gb, and dual layer DVD holds 8.5 Gb of data).
A DVD player can read both CDs and DVDs, but a CD player cannot read DVD discs.
Dec 30, 2009 | Dell Insprion 4F778 (4F779) DVD Drive
Jensen vm 9410
some of the newer dvd's are made double layer and recently they've been working on triple layer dvd's. basically a single layer dvd holds 5gb of information, a dual can hold 10gb and a triple can hold 15gb (those are approximates). by making it more layers, they can put the fullscreen and the widescreen edition on the same movie disc. some of the 'lower end' dvd players don't have the capabilities to play these dual or triple layer discs.
Sep 21, 2009 | Jensen VM9410 Car DVD Player
Region Selection
You cannot change the region code again after 5 times of changing even if you move it to a new computer or install a new OS on your computer, I recommend buying a new DVD Drive to access full functionability and no restrictions.
Jan 12, 2009 | Hitachi LG GSA-4120 DVD+-RW/RAM 12x Burner...
Hi, I bought Bose 3 2 1 SERIES 11 Home system. but i cannot play wedding dvds on my system. All hollywood movies plays ok. I tried Verbatim DVD R & DVD-R there is no picture but the sound is there....
I would say that as with many manufacturers, the Bose 3-2-1 is meant to play Dual Layer DVDs. Since they hold data on 2 separate layers of the disc, these hold twice the amount of data than the Dvd+r or -r that you're using. When the Bose system tries to read the 2 layers and only finds one it, will not recognize the dvd. If you don't have a Dual-Layer burner and Dual Layer discs to burn to, you should upgrade your burning equipment. They're not that expensive these days. Cheers!
Nov 07, 2008 | Televison & Video
New DVDs won't play
What studio label? Some Newline DVDs appear to have some new protection, newer than the Sony ArcOS protection (or whatever it is called).
Jan 18, 2008 | Toshiba SD-2700 DVD Player
Need help w/my DVD player
the problem is in the quality of the player suggest getting a better brand player
Jan 17, 2008 | Microsoft Xbox 360 Console
Player freezes on Dual-Layer DVD+R's... any ideas?
Its probably compabitilities issues. Try -rs. There a lot better since they are more known type and technology. the difference is +r have more editing features but in your case it doesn't matter because your just copying.
Dec 31, 2007 | Philips Magnavox MWR10D6 DVD Recorder
DVD Freezes during playback
it might be that you are playing a dual layer dvd in the player. The player needs to focus on the second layer of the movie, and that might be why the dvd freezes. Leave it there for a while and the dvd should continue if it is this situation.
Dec 08, 2007 | Sony AVD-C70ES DVD Player
Freezing?
any commercial films are written to what's known as dual-layer DVD discs, which are like two DVDs sandwiched together. Movie studios try to pack as much cool stuff as they can onto a DVD, so by the time you add movie trailers, documentaries, and other special features, the amount of space necessary far exceeds the 4.7GB capacity of a regular DVD disc. Using a dual-layer disc expands the capacity to 9.4GB, which is enough to hold the movie and many extras, depending on how long the film is. What you seem to be experiencing is a problem related to the DVD player changing layers (when it must adjust the focus of the laser to read the second layer of the disc), which is usually indicated by a brief pause during playback. In the early days of DVD, many players had difficulty during the layer change, which could cause the DVD player to lock up during playback. In other cases, a badly formatted or damaged disc could be the culprit, so you should check the condition of the DVDs that are giving you problems. Since you mentioned that sometimes they work, your problem could stem from a scratch or a fingerprint. But, if the condition of the DVD is flawless, you may have to consider getting your DVD player repaired, replaced, or exchanged (since you mentioned it was new). Since it is a portable DVD player, you may want to try running the DVD player when it is plugged into an AC receptacle. This will at least rule out any relationship to the battery, though a remote possibility. But, portable devices do strange things when its battery is low. Many commercial films are written to what's known as dual-layer DVD discs, which are like two DVDs sandwiched together. Movie studios try to pack as much cool stuff as they can onto a DVD, so by the time you add movie trailers, documentaries, and other special features, the amount of space necessary far exceeds the 4.7GB capacity of a regular DVD disc. Using a dual-layer disc expands the capacity to 9.4GB, which is enough to hold the movie and many extras, depending on how long the film is. What you seem to be experiencing is a problem related to the DVD player changing layers (when it must adjust the focus of the laser to read the second layer of the disc), which is usually indicated by a brief pause during playback. In the early days of DVD, many players had difficulty during the layer change, which could cause the DVD player to lock up during playback. In other cases, a badly formatted or damaged disc could be the culprit, so you should check the condition of the DVDs that are giving you problems. Since you mentioned that sometimes they work, your problem could stem from a scratch or a fingerprint. But, if the condition of the DVD is flawless, you may have to consider getting your DVD player repaired, replaced, or exchanged (since you mentioned it was new). Since it is a portable DVD player, you may want to try running the DVD player when it is plugged into an AC receptacle. This will at least rule out any relationship to the battery, though a remote possibility. But, portable devices do strange things when its battery is low.
Jun 12, 2006 | Cyberhome CH-DVD 300 DVD Player
GoVideo Go Video DVD/VCR Combo Logo
50 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
