Question about Dryers
Simpson dryer 1200p motor wire install
The I had remove the motor for the unit another reaqson which is now resolved. I have repace 5 of the 8 wires to the motor, but there are 2 brown wires and 1 orange/brown wire, which I'm not sure were they go, 1 of the brown wires is the phrase mains cable in, the other 2 I believe are the element
Obtained the circuit diagram from the supplier
Posted on Sep 01, 2008
Simpson esprit 550 top loader washer
Have you tried the motor control switch.
Its located below the selector switch.
Its white aprox 5 x 7cm with Electrolux AMD103 stamped in it.
The wires that are plug in it goes to the selector switch.
Apr 30, 2016 | Simpson Washing Machines
How to wire Simpson 1200S dryer motor
Check with Simpson directly to obtain the diagram.
Jun 10, 2014 | Dryers
Simpson 1200p won't heat. Sure the element has been disconnected during repairs.
When you repair a unit for one issue and after suddenly have different one it is usually man made--someone should go back over what was done to see if a plug or wire is not connected etc.
Dec 21, 2012 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Model RED4440sqO; will not run. Repaced both 30
Remove the rear panel on the blower housing there is a cycling thermostat (part number 3387134) with internal bias heater and a thermal fuse (part number 3392519). The latter is wired in series with the motor which will cause the motor or the dryer as a whole not to start or run when it has failed. Grab a volt-ohmmeter and set the scale to R X 1 then disconnect a wire from the thermal fuse and check its continuity. Replace the thermal fuse should it read open including the cycling thermostat.
Most likely the motor thermal overload has failed if there's power to the dryer and the thermal fuse replaced but the dryer still doesn't run.
May 24, 2010 | Dryers
How to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Aug 29, 2009 | Dryers
F11 error
Hi
Thanks for using FixYa. Error F11 means it is a serial communication error between the Central Control Unit (CCU) and the Motor Control Unit (MCU) and the communication cannot be sent correctly to these units and the washer. To resolve the issue you are facing with, please check the wire harness connectors to the MCU, then the motor and Central Control Unit (CCU). Also please check the drive system for any worn or failed components, MCU, CCU, motor and wire harness.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Whirlpool WFW9600T Front Load Stacked...
Clothes dryer stops
sounds like the drive belt has stretched, or the auto tension is low.
disconnect power and remove back cover, clean inside around motor resitor block wires, and inspect/ replace faulty components. good luck!
Jan 30, 2009 | Dryers
Simpson Clothes Dryer wont start without assistance
your dryer has a start assist compressor go to this site to see it and that could very well be the problem. www.repairclinic.com/SSPartDetail.aspx?s=t-39p400-%3d%3db166i938994%PartID=938994
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
135 people viewed this question
Top Dryers Experts
