Question about Dell PowerEdge 2600 Server
Problem with creating array
I have dell poweredge 2600, i installed 3 scsi HDD, i want to enable raid 4 & how can i do mirroring of this HDD
    Novelist:
  • 159 Answers
Ctrl M during power up ..
Posted on Nov 29, 2008
    Genius:
  • Dell Master
  • 1,056 Answers
The Perc RAID controller in a 2600 doesn't support RAID 4.
You can do RAID 0, RAID 1 and RAID 5.
With 3 HDD's your best bet would be a RAID 5.
Mirroring is RAID 1 (which would only use 2 of the drives)
Posted on Sep 01, 2008
Disk 4 "is not ready"
> it does detect it on controller initiation.
Even when the drive is not spinning, it will identify itself (manufacturer, capacity) when queried. So, it's possible that it "checks-in", but files/directories on it cannot be read.
Apr 04, 2015 | Dell PowerEdge 2600 Server
Need to increase the hdd size in a dell poweredge 1600sc with raid 1
You will not be able to increase the hdd size of a raid array, it's size is set. If you need more storage, you can add additional drives ( either in raid or standalone ) and use the new drive(s) for storage, but the original array will remain unchanged. The other option is to back up all of your data, install new drives and create a new array.
Feb 10, 2011 | Dell PowerEdge 1600SC Server
Dell poweredge 2600 server recently display a message " No boot device available Press F1 to reboot or F2 to setup" Please why?
Did you experience a power event? Go to BIOS (F2), and make sure that RAID is Enabled. If RAID got turned off (power event, BIOS reset), then it will give you that message. If RAID is already enabled, then you may need to repair your operating system. If something else happened (drive failures, drives removed, etc.), then the array may be completely gone. Call Data Recovery services if it is critical you retreive the data.
Aug 03, 2010 | Dell PowerEdge 2600 Server
My dell 2600 cannot identify the hard drives even from the bios.somebody mentioned the raid card.any ideas??
Have you used SCSI drives? I think it should have 80 pins. What was the SIZE of the HDD? You must have the EXACT SAME SIZE for all the Available Hard Drives. Its RAID. You must install (2 or 3 or what ever the number) hard drives with exact the same capacity. IF you have used/ are using 40 GB then you have to use the exact same size. You cannot CHANGE the Size. Then the Raid Array will Fail. If you are using RAID 5 or any similar technology then No Chance.
And you must Launch the "Rebuild Array".
If you have errors while Rebuilding: I would suggest updating the firmware on the remaining drives as there may be an issue with SCSI timeout errors that caused your disk to fall off its array.
Firmware Updates for Windows Server 2003...
Feel free to contact me again.
If the Solution worked for you, please be kind enough to "Rate" the answer with a "Testimonial" Thanks for contacting Fixya!
Jun 11, 2010 | Dell PowerEdge 2600 Server
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
Getting problem when starting to boot up it starts loading and stick on the boot menu
What is your configuration is it Raid or Scsi?If its Raid you may need to re-create the Raid Array.Enter the Raid Array if this is the case make sure the drives are all on line.If its Scsi you may need to check the boot Drive.You may need to provide some more information in order for me to help you.
Dec 03, 2009 | Dell PowerEdge 600SC (Refurbished)...
CAn I disable RAID on a DEll powervault 770n server
Its called the JBOD RAID option - just a bunch of discs.
I don't know of any system that makes a RAID array an operational imperative, I would say the answer to your question is yes.
RTFM.
Oct 04, 2009 | Dell PowerEdge 2600 Server
Maxtor SCSI 36GB hard disk drive was removed from
if you are using raid go into the perc hardware utlity as it boots,try formating the drive there.maybe this will work.If you are using the dell open manage software you can probably format it there in windows.If you are not using raid enter the scsi utlity and do a format there.
Good luck
Sep 09, 2009 | Maxtor Atlas 10K III 73.4 GB SCSI Ultra320...
I'm having some trouble with a dell poweredge 2650 I bought off eBay.
You are not too clear, however I'll take a guess ..
1) Booting from CD ... older CD drives fitted to PE26xx range do not recognize Windows 2003 bootable install CD's .. the TS-L462C (a laptop drive) should be compatible with the PE 2650 (I know it works in my 2600)
2) Installing the Operating System onto the PERC SCSI Array drives .. a total pain .. with older OS (Windows 2000) you can use the 4 x floppy disk set to install and hit (F6 ? as I recall) to tell it to 'load a 3rd party driver' ... get the PERC drivers from the Dell site.
Alternative = toss the useless Tape Drive and install a set of SATA drives in the same space (a 3 drive Hot Swap caddy eclosure will fit = Icy Box or StarTech) .. you will need a PCI RAID card (such as Si3124) since the M'Bd has nothing but a combined floppy/TapeDrive IDE interfafce.
3) Finally, be aware that this is a SERVER level box .. spare parts & Dell 'official' upgrades are going to cost you an arm & a leg = and don't even ask what the special 'ECC parity' Memory sticks cost :-)
Jan 22, 2009 | Dell PowerEdge 2650 (PE2650BB) Server
PowerEdge 1750 can not recognize the Local Harddrive
I think you need to provide heaps more info, like what operating system etc.. Have you tried to change the interface to another port eg if IDE, then move the cable to the secondary or if sata test the drive with another cable/port.. Have you tested the drive in another computer? OK, if it's scsi, then does the drive need a termination? Most scsi drives need a dongle or a terminator to allow them to be recognised.
Apr 26, 2008 | Dell PowerEdge 1750 Server
Dell PowerEdge 2600 Server Logo
459 people viewed this question
Alun Cox
