Question about Belkin (F5D7230-4) Router (587009)
Firewall How do I turn off the fire wall so I can use my magicJack phone jack?
  • Kats7 Aug 31, 2008
    How do I open 5060 and port 5070?
  • 905 Answers
To both questions, type in the # address that belkin provided to you or the default gateway address into your internet browser , once there click on firewall or virtual servers ( the security code it asks for by default is blank , just click submit ) and then you can make changes in the belkin utilitys.
make sure to click APPLY CHANGES before logging out!
Posted on Oct 07, 2008
My magic jack plus will not work and I am wondering if the electrical connector is bad.
Go to the magic jack website and update your adapter. Also try different USB ports and reboot your computer with magic jack connected. If the computer does not recognize the adapter, try disconnectin and reconnecting into different ports. There is a update option on magic jack website and tech support as well.
Nov 04, 2014 | magicJack PLUS VOIP Phone Adapter
My magicjack is not working
Have you check the breaker for the circuit its on? Is there power to the jack? If yes try using it on another jack/phone or at a friends place see if it works there. If it does the problem is either with your phone or computer connection/setup, if you are using one.
Nov 04, 2014 | magicJack Plus
Why won't my magic jack work plugged into the wall outlet?
Magicjack uses the internet. It has to be hooked up to a computer using the internet. Its just skype for regular phones. Skype is free. magicjack cost 20 bucks. its a scam
Oct 27, 2014 | Cell Phones
I can call out on my Majic Jack Plus but cannot receive calls. The majic Jack is registered and set up on my modem.
This could be failure of the power adapter module.
Is your Magicjack plugged into the wall power thru a power adapter? Try bypassing the power adapter and plugging the magicjack directly into a USB port on your computer. If the magicjack work correctly now, then you have a bad power adapter module.
I had a similar problem. My Magicjack was plugged into a wall socket. First the dial tone became inconsistent, then I could no longer receive calls, then it died completely.
I plugged the MJ into a USB socket on my computer, and it then worked normally.
If you have a failing power adatper, it will continue to deteriorate, and it will eventually fail completely. The blue power on the magicjack will not come on when it is plugged into the power adapter, but it will illuminate when plugged into the USB socket on the computer.
Note: the computer must be on to power the magicjack thru the USB port.
Magicjack is aware of the problem and offers a replacement power adapter module. To contact them, go to www.magicjack.com and go to "support". They will ship you a new power module for about $5.50. Some people have reported that the replacement modules from Magicjack are no better than the originals and have had repeat failures.
Consider getting a power module from another source. There are lots of AC to USB power converter modules available on Ebay for only a few dollars. Search Ebay for "magicjack power adapter".
Oct 05, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
I changed computers now magicjack will not come on
On a new computer, you have to reinstall the magicjack software.
When you plug the magicjack into a USB port for the first time, you should get a message about installing software.
Something like: "Install or run program from your media".
If you powering the Magicjack directly from the wall AC and are not using a USB port, be sure the ethernet and phone lines are both connected.
Oct 03, 2014 | magicJack Usb Phone Jack - As Seen On Tv
My Majic Jack Plus is not working ,the light is not coming on.
,M MK,MVCOKJKVCJIIJCVXIJIHJVLLLFLMPFKKKKFHJUGDKKHDFSUHGHTCSDGFYFTYTASDFSD HFYVSDFYGVASD SDYYSDYTF ASAVYSJUUASTFSDISDJJDHSHYUSDYGBSDYGUJKSDFIHDFSHSDYCAS6FTBB BASDUGTTSDFYG7SDBB DFUSDGVGGSD7FUIYUASVBB SDUTASDYFSDTYASDFYXSUSDFGFODFGSDGASDFSDFUSD
Dec 14, 2013 | magicJack Two, 2 Magic Jack Plus Voip...
Cannot connect to gotomeeting
Consult Customer support, it may be they are incompatible or Firewall/router problems exist.
International VoIP Phone Service Customer Care Support magicJack
Feb 13, 2013 | magicjack.com
We have a problem with the majic jack adapter. It does not work when plugged into the wall. It only works when plugged into the computer. This is a new 5 yr warranty majic jack that was working when...
This is a common problem with the magicjack. It works when plugged into a USB port on the computer, but not when plugged into an AC wall socket. On the magicjack plus there is a blue power light near the word "plus". If that light is not on, then it is not getting power.
The problem is in the seperate magicjack power supply module.
When the magicjack is plugged into your computer USB port, it is getting power directly from the 5 volt source in the USB port.
In order to use AC wall current to power the magicjack, a power converter module is needed. That module contains a transformer and rectifier that coverts 115V AC into 5V DC. It is that power converter module that is failing.
The power converter module has an AC plug on one end and a USB socket on the other end. In order to power the magicjack from the AC current from the wall outlet, you plug the power adapter into the wall socket and the magicjack into the USB socket on the power supply module.
I had the same problem with my magicjack. I measured the 5V output of the power module to be only 3.5V. I took the power module apart to figure out why it failed. I found two 220uF 10V capacitors that were labelled "Low ESR" (C8 and C9). I measured the ESR of these caps and C8 was 1.5 Ohms. I replaced that cap and it fixed the problems. These two caps are circled in red in the photo.
I do not recommend repairing these power modules. I did it out of curiosity. These modules are very cheap. There are lots of AC to USB power converter modules available on Ebay for only a few dollars. Search Ebay for magicjack power adapter.
problem-majic-jack-adapter-not-work-mbz13odsyguuiirp1214tyyc-5-0.jpg problem-majic-jack-adapter-not-work-mbz13odsyguuiirp1214tyyc-5-1.jpg
Nov 16, 2012 | magicJack Two, 2 Magic Jack Plus Voip...
I installed Magicjack on my Samsung Galaxy 3 and it was working no problem. Now I get magic jack network error 20 and it wont work.
The website you are trying to logon to is blocking access or you have installed anti-virus software. If your magicJack reads "Error 20", please make sure that you have allowed exceptions on your Firewall/Antivirus for magicJack. For fixes go to this page
What Is Voice Over IP Frequently Asked Questions magicJack
and put in error 20 in the search box and press enter. You can download the pdf file which has the solutions for the most common Firewall/Antivirus programs.
It is 86kb long, so is too long to reproduce here.
Oct 30, 2012 | magicjack.com Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
192 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
