SOURCE: My camera is showing an error code. How do I trouble shoot
normally this problem comes when the apparture selector ring is not sat to highest appartutr. i.e. f22 or whatever highest apparture available with the lense. just lock it there .
SOURCE: loading film in my vintage camera..help!
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
SOURCE: Canon AE-1 won't rewind film without tearing it up.
misstigeress,
is the film being ripped along the sprocket holes? if so, the rewind button is not unlocking the drive sprocket. with film removed open the film door and push the rewind button in, the drive sprocket should turn freely. now charge the shutter with the advance lever. the rewind button should pop out and the drive sprocket should not turn freely.
if the sprocket did not turn freely with button pushed in, the camera needs repaired. there are no new parts for this model canon so any parts needed will be good used.
SOURCE: I have an old 35mm Canon Sure Shot 70 Zoom. There is
You don't need to open the camera to change the film. The battery door is on the other end. You open the door by inserting the protrusion on the plastic end piece of the strap into the slot of the battery door. It takes a small 3 volt battery.
Does your camera show any signs of life at all? Have you tried new batteries?
