When I turn the tv on it goes off. I have tried pulling the plug, wait a few minutes, plug it in and then turnit on. This worked initially but not anymore.
  • quarles635 Aug 31, 2008
    Sorry but my TV is not a rear projecion TV. It is an HD LCD TV. It's a 32" Wide-Screen AKAI brand, model LCT3201AD
  • 19,396 Answers
Often this is due to a problem with power adapter.
Less frequently it is an internal overheating problem or an other internal fault.
Here is powe radapter for $67:
A call to a repairman to diagnose the problem will cost you $80
Posted on Aug 31, 2008
    Genius:
  • 1,011 Answers
Sir,
Maybe your TVs are getting overheated, so my best guess would be that it's the power in your flat. i suggest buying yourself a surge protector and plugging your electronics into that.
thanks
good luck
    Sergeant:
  • 241 Answers
TRY THESE STEPS
>Check the buttons on the TV make sure they are clean and not sticking.
>Check the Remote Control buttons and see if they are sticking
>Clean the Face of the infer Red lens to the remote and the TV...
clean them with a small rag or paper towel (Do Not USE Abrasives to clean any part of your Electronics)
>Check the plug for any defects
>Reset your tv back to it,s factory settings
>And if any thing locate your user manual and find the 1-800 number
  • Jayson Brollini
    Jayson Brollini Aug 31, 2008
    OH is there a chance that you have the SLEEP mode set on a connected device that is on a timer. Silm and Rare but .. worth a check
  • 6,487 Answers
What is the brand and model of your Tv so we can help you better??
  • 3,037 Answers
Well, have you had a look at the capacitors on your tv. They are probably bad especially if they look like they are swelling. As soon as they swell up, your tv stops working. Simple as that
  • Benjamin Patri
    Benjamin Patri Aug 31, 2008
    I never said that it was a projection tv. Basically all electronics have capacitors and if you choose not to pursue the option of checking them, then I can't help you because I need you to help narrow down the problem with my guidance
Wont turn on
Unplug the power cord, wait a few minutes then plug it back in and check for a loose connection where the cord attaches to the TV. If it won't turn on after that, it's time to use the warranty.
Jul 16, 2014 | Sharp Aquos Televison & Video
Troubleshooting con
Make sure that the power cord is plugged in and press Power on the TV and/or remote. Make sure that the correct video input source is selected (HDMI 2, etc). Try another channel; the station may be experiencing problems.
You can also try power cycling the TV, by turning it off & unplugging it for a few minutes. Plug it back in, turn it on and restore settings back to factory defaults. If issues still persist, I would recommend pursuing repairs.
Oct 01, 2013 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Jul 16, 2010 | RCA HD52W66 Projection Television
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Trouble changing device
Your problem may be solved by re-initializing the set. With the tv on use the remote and push MENU,2,1,7,0. A display will come up. Use the up down arrows on the remote to select INITIAL and press the enter key on the remote. That should do it.
May 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Picture goes off
A temporary solution is to unplug the TV for a few minutes, remove static from the glass with your hand. It is important to unplug rather than turn off. If you have a degauss button you can also press that before unplugging. Wait several minutes or an hour. Then plug it back in. If you have Picture in Picture it may be an issue with that and to permanently solve may need a repair person. The unplugging may get you by for a few days at a time. That's at least better than an hour.
Mar 13, 2009 | Fisher PC-32S90 TV
RCA HDTV model#HD52W59. When I turn the power on it stays on for a few seconds and then goes off by itself.
TV turns off unexpectedly
• Sleep timer may have been activated.
• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this
happens frequently, the voltage in your house may be abnormally high or low.
• Unplug the TV. Wait ten minutes. Then, plug the TV in again.
Jan 05, 2009 | Televison & Video
Sony TV power and volume not working
Since remote does not work, try taking out batt and turning on by set. See if still turns up. It could be that the up button is jammed inside set. Does everything else works? See if you can go to menu and turn speakers off, this will allow you to work on set and not worry about noise.
Sep 04, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Electro Med Services...
