I have an Arcsoft ION slides and negatives to PC scanner. It was working fine, then in mid batch of negatives the live pickup failed and will not scan the negatives or slides. Total mystery. What can I try to get it working again. I checked all the connections etc.
  • Computers & ... Master
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
Posted on Jul 27, 2011
SOURCE:
Why do my slides only show as negatives
There may be a setting in the software to enable you to correct this - if not, then you'll have to deal with it in post-processing.
Jul 23, 2016 | ION Audio ION FILM 2 SD 35mm Film and...
My scans look like a negative and not a photo
When you go to scan your slides, the software should have a setting for "slides", or "negatives". Make sure you select the correct one for what you've put in.
Dec 31, 2014 | ION Audio ION FILM 2 SD 35mm Film and...
In spite of the fact that I properly downloaded and installed my ION Film 2 SD Plus Slide and Film Scanner into my Toshiba Laptop computer, I cannot scan anything into it. I repeated the downloading a
i am surprised that it is not a stand alone scanner. for almost the same price i have a wolverine which basically works on mains power, or powered from laptop. it scans and stores the images in the unit. those can be later transferred to the laptop while connected via usb. one question, does the scanner lcd show the scanned image? if not may be something is wrong with the unit itself.
Nov 25, 2014 | ION Audio Film 2 SD Plus Slide and...
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
Arcsoft Photo impressions 6 software
I have the same problem. If I try to scan my colour negative it comes up totally blue. They are not very old negatives either and have been stored in the dark since developing. I can use the Black and White option quite successfully but have given up on achieving colour.
Nov 04, 2009 | Arcsoft PhotoImpression® 6 Full Version...
I have purchased a ION slide to PC scanner, It is plugged into a USB2 port, My system runs on Windows XP Pro with a NVIDA Graphics accelerator, V2.70 with latest updated driver, an AMD 1.01Ghz processor,...
change your desktop settings for a higher resolution, such as 1024 x 768
1. right clich on desktop
2. select properties
3. select "settings" tab
4. change "screen resolution" to a higher resolution ("more")
5. accept changes and try scan again.
Sep 01, 2009 | Office Equipment & Supplies
Require driver for Ion Slides 2 PC ... using Vista 64 bit.
MY ION SLIDES 2 PC WORKED WELL WHEN I HAD VISTA BUT SINCE CHANGING TO WINDOWS 7 IT WILL NOT WORK WHEN CLICK ON AQUIRE I GET THE MESSAGE CANNOT FIND THE SCANNER. PLEASE CONNECT 35MM FILM SCANNER. I HAVE UNINSTALLED THE PROGRAMME AND REINSTALLED IT BUT SSTILL GET THE SAME.
Feb 22, 2009 | Office Equipment & Supplies
Slides scan as negatives
this scanner usb cabal no didact tell me bored problam ya cabl problam 6600E
Feb 04, 2009 | Canon CanoScan 4200F Flatbed Scanner
Cannon 4400F Scanner
I had the same problem with about 1 out of every 16 slides when I first got the scanner. The only way I found around it was to rearrange the slides and try again. I started scanning through the ScanGear software instead of Canon Toolbox, and haven't had that problem since. I've scanned about 6,000 slides and negatives so far.
Jan 25, 2009 | Canon CanoScan 4400F Flatbed Scanner
Redish/Pinks color to scans.
You need to reset your scanner's color management settings to default..
Which utilty software r u using?Arcsoft Photostudio?If yes go to Edit ->preferences
Set RGB settings to the same level(adjust the slider next to red)
If it doesnt work or u r not using arcsoft..post back..
Nov 04, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Computers & Internet Logo
114 people viewed this question
Alun Cox
