Question about Frigidaire Dishwashers
Frigidaire 24" FDB1050REB2 Dishwasher It will not allow water to come in. The pump works, the motor runs, but it will not fill up. Water valve has been replaced. Pleas help!!
  • michellek657 Sep 01, 2008
    The dishwasher is only 17 months old. Spent $50.00 on replacement parts and my husband done the repairs. Trying tosavemoney and don't want to spend much more. Thanks anyway.
  • 639 Answers
Friend,
ngfam1 At your service!
You plain old need service ! I am not hands on from this side of the wire!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New applinces are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
No water in dishwasher
Hello Lupe Espiricueta - Is the unit making a grinding noise? Is the house water valve turn on? Is the door closed tightly? If so, but dishwasher still does not fill with water I would suggest contacting a professional to move forward accurately and properly diagnose the unit. The unit could possibly have a miscommunication with the connector and wiring connection or a defective drain motor/pump
Nov 30, 2012 | Frigidaire 24 in. FDB126RB Built-in...
I have a dishwasher when i put the detergent in it, the detergent doesn't dissolve while its washing. i often have to rewash the dishes, and it still doesn't dissolve.
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Nov 18, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Dishes come out pitted and feel dirty. I have
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Nov 08, 2009 | Frigidaire 24 in. GLD2162RDC Stainless...
Dishwasher makes squeeling noise when filling with water
if the dishwasher is only filling when u hear the noise it could be a bad water valve or if you are lucky it could be the screen in your water valve is dirty, however if it is filling and washing at the same time and you hear a noise like sqeeling it could be your motor, before u replace the motor. check the water valve or screen on valve may be dirty
Sep 16, 2009 | Frigidaire 24 in. GLD2350RC Energy...
Dishwasher always fills to float valve
There are actually several possible causes of your problem. I will briefly describe each in hopes that you can isolate the problem and will then know how to proceed.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Aug 02, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
GE dishwasher will not fill with water
is the filling valve on the inlet water working unscrew the connecting pipe and see if the water is actually comeing out of the pipe. sometimes when the tap runs at the same time it takes a lot of the water rather than the dishwasher getting it. depending on the pressure. otherwise it might be the ****** pump. try wd 40 on it. it might be jamming.
Mar 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not fill with water
there are three or 4 possibility's here remove the kick plate make sure the water valve is plugged up make sure the water is turned on make sure the safety float hasn't slipped off the micro switch that's the dome shaped object in the tub the micro switch is underneath next when you first turn it on do you hear the pump motor run check theese and let me know
Feb 17, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire 18" dishwasher
Check the electrical water inlet valve for sand or unwanted partical on the valve. If the valve can not be open and clean, change the valve.
Nov 16, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire dishwasher
CHECK WATER INLET SOLENOID OR TIMER
Jan 26, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
175 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
