Question about Samsung Digimax 4500 Digital Camera
Digimax 4500 shutter response
I have tried to take pictures of people jumping in the air (kind of a hobby of mine) and it seems hard to tell when the shutter is really going off.. I tried counting to three (for folks to jump on three) and pushed the shutter on two and they were still up and back down before it went off. Is this normal and/or can I force the shutter to go at the instant I press?
  • Samsung Master
  • 5,471 Answers
Unfortunately, delayed shutter response happens on some digital cameras.
Posted on Sep 10, 2017
4 Suggested Answers
advance
  • 107 Answers
SOURCE: digimax i6 pmp SHUTTER problems!!!
Congratulations on fixing the problem! However I just wanted to let you and everyone else who reads this solution know that the part which failed on your camera is not actually the shutter. The shutter is deep inside the lens assembly right next to the image sensor. What you were dealing with was simply a protective cover for the lens. David Millier Advance Camera Repair
Posted on Feb 24, 2007
  • 383 Answers
SOURCE: my samsung digimax s500 camera still says card locked every time i go to take a pic.Someone kindly sugested holding the rest button, but i
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
Posted on Oct 16, 2008
SOURCE: the shutter lens to the Samsung Digimax S500
This normally happens when the batteries are going flat. Replace batteries and the problem should be solved.
Posted on Jan 24, 2011
When i try to take a photo it comes up with F 2.8 1/30 on the screen for Samsung Digimax S500 Digital Camera. How can I fix this?
When the camera refuses t make a picture, please try putting the main dial to the automatic setting. (most camera's do have that little green camera logo on the dial. Put it there. Then try again.
When you tried one of the manual settings or the scene settings, and the camera does not get enough light, it could be it refuses to take the picture. Same when it can't focus, because there is not enough contrast.
Mar 07, 2015 | Samsung Digimax S500 Digital Camera
When i try to take a photo it comes up with F 2.8 1/30 on the screen on my Samsung Digimax S500
There's nothing to fix. These numbers aren't showing up on the picture itself, are they? The camera is simply telling you the aperture and shutter speed for the current picture (f/2.8 and 1/30 of a second).
Oct 08, 2014 | Samsung Digimax S500 Digital Camera
I have a fujifilm 10megapixel camera. It doesn't let me shoot any more. when I press the shutter, the camera goes into viewing mode. I have tried reset option as well. please help
I tried your '3 times a second' and that works on mine too. Went to Future Shop (where I bought it) and basically said its a write off.
Feb 07, 2011 | FUJIFILM A170 Digital Camera
Camera turns off when shutter button is pressed.
[source]Question about Samsung Digimax S500 Digital Camera[/source]
Try replacing batteries (high Ah photographic type).
The lens motor & electronics may be draining power if Ah capacity has dropped too low. At night, it could be that your flash is trying to fire (another drain), or shutter timer / mirror staying open longer.
Sep 20, 2017 | Samsung Digimax S500 Digital Camera
My samsung digimax s500 camera still says card locked every time i go to take a pic.Someone kindly sugested holding the rest button, but i
Oct 16, 2008 | Samsung Digimax 530 Digital Camera
When using flash, my sony cyber-shot dsc-t10 takes forever to take pictures!
Have you tried Hi-Speed memory cards, as writing speed of the card affects the response time of camera, I am using Sony MSX-M2GN 2GB and it's gives me quite good response.
Other thing you might try is format the memory card using camera, camera has card format functionality and it does also improve the performance of the camera.
Jul 16, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Camara powers on but will not snap picture!
did you just try to press the shutter button halfway?if yes...press in all the way through...if still does not take a picture..master reset...
-press menu
-press right to go to setup
-go down to reset
-highlight yes then press menu to ok it
-turn off then on then try to take a picture
hope it will help...(",
Dec 26, 2007 | Samsung Digimax S500 Digital Camera
My camera seems to short out and there are horizontal lines in the pictures.
get new batteries, if recharging your current batteries does not work (to stop it shorting out).
reduce your shutter exposure, by changing to Manual Mode (M), selecting +/-, and then the left button (flash) around the Menu OK button. Mine works fine at 1s shutter speed, but was showing horizontal lines before that ...
Nov 10, 2007 | Samsung Digimax S800 Digital Camera
Shutter will not open/close (Disengaged from motor - "flopping" loose)
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 19, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Samsung Digimax 4500 Digital Camera Logo
52 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
