Question about Sewing Machines
Stop Motion Knob
When trying to wind the bobbin, I must first stop the up/down motion of the needle, and I am unable to do this on my White Model#1418. On the motion wheel , when I hold it with one hand, and try to turn the inner knob, the inner knob will not turn.
Have I given enough info?
I would appreciate your help.
Best,
Jim Crowley
  • 1 more comment
  • Anonymous Mar 22, 2014
    holding balance wheel stop motion knob wont turn
  • Anonymous Mar 26, 2014
    I cannot disengage the flywheel when I need to wind a bobbin. The inner knob does not move, it seems o be stuck. Can I fix it myself ?
    I cannot disengage the flywheel when I need to wind a bobbin. The inner knob does not move when I try to turn it towards me. Is seems to be stuck. What can I do to fix it myself if possible ? Thank you.
  • 323 Answers
Dear Jim,
I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers.
sewman7
Posted on Sep 03, 2008
Why won't the motion stop knob will not move?
Look carefully for thread caught around and under the knob. If you can't get it to turn and find no reason why it won't, you can probably delay fixing it until the next time it's due for its yearly "tuneup" (COA, clean/oil/lubricate) by taking the needle out before you wind a bobbin.
Jun 02, 2014 | Husqvarna Husky 145
I have a Mega Quilter and would like to stop the needle from working up and down when I wind my bobbins. Do I do this in the menu of the read out?
Most machines with a bobbin winder on them have a round knob inside of the machines flywheel. That's the wheel that turns when you sew.
TURN the inside knob forward or reverse to lock or unlock the main gears from turning the needle bar in the sewing motion.
Easy
Cheers,
Kelly
San Diego, CA
Apr 27, 2014 | Sewing Machines
Singer 974 MY NEEDLE WOULDN'T MOVE WHEN I TURN THE HAND WHEEL AND MY HAND WHEEL WOOBLES. HOW CAN I FIX IT?
slacken the small stop screw and remove the centre free motion knob. the balance wheel should now be free to turn independent of the shaft. you will have exposed the friction washer. clean all surfaces and relocate the washer with the two locating lugs facing outwards into the two slots in the shaft and refit the knob and screw. if the screw bottoms on the friction washer remove knob and turn the friction through 180 degrees and try it again
Feb 21, 2014 | Sewing Machines
Stop motion knob will not disengage the needle when winding a bobbin
The stop motion knob on most older sewing machines is very much the same. You should find a small screw on the face of the knob. Loosen this but don't take it all the way out, it is real easy to lose and hard to find a replacement. Loosen it until you can turn the knob counterclockwise past the stop. Now remove the knob and there will be funny shaped washer underneath. Pay attention to how it goes on, you will have to put it back the same way.
Now to the "why" of your problem. The assembly has run dry, no oil, and the hand wheel should turn freely on the center shaft. You may be able to get some oil in with no problem or you may have to remove the motor belt to remove the hand wheel.
I find this a lot on old machines, nothing broken, just no oil.
Good luck,
Bob
Feb 05, 2014 | Montgomery Ward Sewing Machines
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
Locking disk on handwheel won't lock and I can't wind a bobbin
If the stop motion wheel is stuck and you can't free it the best way to do it is to stand at the end of the machine, get something that looks like a chisel or something that has a flat end even a screwdriver, put the end of the screwdriver in a slot on the left hand side of the stop motion and give it a sharp thump down, it worked for me for years, the only problem you may have is if you do not have any slots or grooves to put the screwdriver in.
Nov 01, 2009 | PfaFF Creative 7570
Stop motion knob won't tighten
Remove the stop motion wheel and you will see another part that is loose(looks kind of like a washer with ears on it). Reposition this on the shaft and put the stop motion wheel back on. The stop motion wheel was too loose and it allowed the washer to fall off the shaft. The screw is nice to have and it keeps the washer from falling off the shaft but it's not absolutely necessary to use the machine. Just be caredul when winding the bobbin.
sewman7
Dec 03, 2008 | Sewing Machines
Sewing Machines Logo
605 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
