Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
Blinking picture and bars running on diagonal
Blinking picture, began as occasional now all the time. also bars running on diagonal,
    Genius:
  • Sony Master
  • 1,689 Answers
A common cause is a short in the electron gun inside of the CRT neck. This is not fixable without changing the CRT. The CRT is terribly expensive to replace if it was available.
A less common cause is a failure in the HV multiplier. This is part of the flyback assembly. Changing the flyback assembly is taking a gamble to see if the fault is fixed this way. There can also be some other support components that will have to be changed.
Considering the age of the set, I would not invest any money in to it.
Jerry G.
Posted on Jan 17, 2009
My tv screen went blank and power light started to flash what could it be
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 04, 2015 | Samsung PN59D7000FF 59 In. Diagonal 1080p...
14 blinks on my Panasonic TC-P50S30. Any Ideas?
Nov 19, 2014 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
No picture on my Panasonic TV
Please unplug all HDMI cables from the TV and test a different electrical outlet. If the problem persists, please use the below link to locate an authorized service center in your area.
Where to Service Panasonic Products
Mar 13, 2014 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
Sony KDL-40Z4100 standby light solid red, orange blinks every 4 sec, What part may have gone bad?
The red stand by indicates the set is in PC stand by the blinking orange timer is indicating the timer has been set or has an issue
Mar 13, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Disk Error Problem
I have the same exact problem. Has anyone helped you with this?
Jun 07, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
Picture bowed up from bottom/black bowed bar.
I was able to find this solution extremely helpful from Troylove11. It fixed my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Feb 24, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Problem with Poloroid LCD 32 in. TV
stiv0's Support Profile at FixYa will give you detailed instructions for repairing your set
Jan 15, 2009 | Polaroid FLM-3732 Television
No picture and tv automatically turns off
Good day.
You are getting an intermittent performance for your unit. One reason for this might be with the loose contacts on the high voltage section of your unit. Have it resoldered.
Regards,
chris
Aug 19, 2008 | Sony KP-48V90 TV
TV picture won't stop blinking
Sounds like a bad solder joint or leaky capacitor. What make and model set do you have.
Jan 11, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
70 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
