Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Western Digital My Book freezes computer on boot up.
My computer freezes up when I go to boot it up while the Western Digital My Book (1TB) connected in the USB drive. My operating system is Windows XP and it freezes on the Windows blue screen. Any solutions?
  • 14 more comments
  • drice2k Sep 01, 2008
    Just got it at costco, and have the same problem. Installed the drivers from WD, and still no luck. Only I am using firewire, and have not tried USB (due to speed). Here is the driver.txt that came with the WD firewire driver.
    This executable will install the 1394 SES Driver (WDC SAM) needed by the Firefly 1CS & 1Q.
    This installer should also be backward compatible with the Galaxy 2T.
  • smtt771 Sep 20, 2008
    I have the exact same problem. I am running XP MCE through USB. I've played around with all BIOS options, but no luck. I was going to buy a firewire card to see if that would work, but it seems not.
    Anyone?
  • Anonymous Oct 25, 2008
    I have a WD MyBook 1TB with USB, Firewire and eSATA Connections. I use eSATA Connection!
    On Boot of Windows XP I get a Blue Screen: Reason is incompatible ACPI BIOS (has to be upgraded). This doesn't happen with other eSATA Disks!
    If i connect the disk when the computer is up, everything is o.k.!
  • Anonymous Nov 11, 2008
    same here.
  • Anonymous Nov 17, 2008
    Solution:
    In the system BIOS, disable the Boot from USB device option and the USB Legacy Support option. Doing this will allow the PC to complete the boot process to the internal hard drive and allow you to enter Windows. If this does not work for any reason, you should boot your PC before connecting the USB drive. Once the computer is fully booted into Windows, connect the USB drive and wait for the operating system to detect the drive.
  • Anonymous Jan 01, 2009
    I have the 250GB WD My Book connected to a USB 2.0 under XP service pack 3, and have the same problem the boot hangs, so I usually fire it up afterwards which is less convenient. I've also noticed that my 8Gig USB stick also causes a similar delay in bootup though for a shorter period. It's as though it is checking the memory on these devices. I've never timed the WD as I don't have that much patience!
  • Anonymous Jan 05, 2009
    I also have a My Book Home edition 1TB drive.
    Mine is connected with Firewire.
    The logo boot screen stays up and XP never comes up when the drive is online. I have not yet tried disabling the bios boot options mentioned in another post, but I think it is lame to have to turn that off. especially since this is not USB for me.
  • Anonymous Jan 06, 2009
    Same problem with a WD MyBook 500Gb...   difficult recognition by system (Xp). Only 1 out of 20 connections....  ???  and when it works usually comes to a system crash within 3-4 hrs.
    WHAT IS WD GOING TO DO????
  • Anonymous Jan 07, 2009
    i have the same problem. when i try to use my 500 gb external drive my book i get an BSoD. - xp sp2.
  • jah0 Jan 26, 2009
    Just for the record, the OS is irrelevant. This happens to me with Vista 64 Ultimate, as well. This is on a Dell Inspiron 530. I am guessing (since it happens before the system starts loading the OS) that the bios switch is the only viable solution.
  • Anonymous Feb 07, 2009
    I have the same problem. I strongly suspect the system is attempting to boot from the Life Book. This problem started only when I started changing drive letters.
  • Anonymous Feb 26, 2009
    I have had the same problem though now I am having trouble starting my pc at all...
  • Anonymous Mar 01, 2009
    i think its xp3...
  • Phillipm58 May 04, 2009
    With the WD External HD connected to computer through USB Cable, computer freezes on startup. The gentleman who stated the issue of the legacy USB switch being diabled in bios is correct. Use a regular connector for mouse and keyboard and lose the legacy USB in the bios. It works.
  • Anonymous May 09, 2009
    I have other USB devices that won't work if I disable the USB Legacy Support.
    In Fact, in my notebook bios thr'es no such thing as USB Legacy Support.
    I own an Asus A4BL with pentium 4 at 3,2 gb, 2Gram, Win XP.
    My hard drive is a Mybook Essential 1TB
  • Roberta Smith
    Roberta Smith May 11, 2010
    it contines to boot fine without the usb drive plugged in ?
Mine boots fine if I unplug (better yet, hold the flat button down on the back for about 5 seconds, and it will turn off).
Posted on Sep 01, 2008
I had this prob as well - disabling usb legacy support in bios setup worked a treat
Posted on Feb 05, 2009
  • J K Sep 28, 2010
    That's really brilliant, but I don't have ANY way to disable legacy USB support in BIOS on my Acer Aspire 5920G notebook. No other ideas?
  • J K Sep 28, 2010
    That's brilliant indeed, by I don't have ANY obvious way to disable USB legacy support in my bloody simple BIOS in an Acer Aspire 5920G notebook. Any other ideas, anyone?
I have had this problem in the past with my external harddrive. You have to go into the bios and turn off legacy usb. But if you have a usb mouse or keyboard (wireless or wired) they won't work. But your pc should bootup with the harddrive plugged in. This was how I fixed the problem with my WD My Book 750GB but I can't promise it will work with anything else. BUT DON'T TURN OFF LEGACY USB IF YOU HAVE USB MOUSE OR KEYBOARD!
Posted on Apr 08, 2009
  • johndoe90 Apr 08, 2009
    Apologies, I must have missed reading solution #1 even though I thought I read it through.
When connecting my WD 1tb external Hard Disc my task bar freezes why?
WHY NOT TRY TO CONNECT WITH PC "SHUTDOWN", SEE IF PROBLEM GOES AWAY..........HOPE THIS HELPS...........JEFFXC
Feb 23, 2011 | Western Digital MY BOOK HOME 1TB EXT...
Every time i plug my 1TB western digital mybook in my computer freezes and when i shut it down it wont restart until i unplug it from the computer i have no idea what it could be please help
That needs a motherboard drivers upgrade.
What happens is that the BIOS starts detecting and checking booting devices.
Earlier motherboards are not able to detect external hard drives and boot from them.
So the solution to this is to turn off the computer and then disconnect the cable.
Remove safely the HD and then restart.
God Bless You!
Feb 05, 2011 | Western Digital My Book Essential 1TB...
My western digital 1tb hard drive is freezing my computer and its not showing up as being connected to my computer
IT is a clear indication that the data transfer from the External hard drive is not compatible with the processor and can be resolved by changing the usb cable.
Jan 21, 2011 | Western Digital My Book Essential 1TB...
My western digital 1tb external hard disk freeze my pc when i conected i must restart after restart is ok
every system has a limit to the devices that can be connected to them.1tb is a very large memory and is capable of making the system or the hard disk freeze causing you to restart.it is most probably that your system cannot utilize it while it is on and so has to be re-boot so as to make the hard disk boot up with the system.one very good sign of this is if your system takes a bit of longer time to boot with the hard disk connected from the start,if so my advice is for you to upgrade your system.like the ram and processors should be increased.hope this was helpful?
Oct 21, 2010 | Western Digital Elements powered by WD 320...
Western Digital My Book Essential Edition 1tb is freezing windows
Sounds like a bad PCB on the drive is bad. It's a known issue with western digital. TechRx, Inc. is an expert data recovery company. We offer free estimates. http://techrxgb.com
Jul 07, 2010 | Western Digital My Book Essential Edition...
Why wont my laptop start with My Book?
disable usb booting in bios, set hard drive and cd ahead of everything in boot order
Mar 15, 2010 | Western Digital My Book Essential 1TB...
How to play music straight from my Western Digital My Book Essential 1TB without having to load it on my computer first.
Set your itunes drive to the external WD drive, easy. Itunes -> Preferences -> Advanced -> Store Location -> Set to your external drive
Feb 15, 2010 | Western Digital My Book Essential 1TB...
Computer freezes on start-up when western digital 1tb external hdd plugged in to computer, computer starts fine with it unplugged. The hard drive can be plugged back in after start-up.
This is a known problem with these drives. Disabling USB legacy support in your Bios should solve the problem., it did in my case but at the expense of not being able to boot from a USB device. Definitley a problem with their enclosure or drive.
Ken D
Aug 11, 2009 | Western Digital MY BOOK HOME 1TB EXT...
1TB Western Digital External keeping system from booting up
You need to go into the BIOS of your computer and change the boot order of your computer.  Your computer must be set to boot from your main hard drive only.
Mar 05, 2009 | Western Digital My Book Essential 1TB...
Problems with Western Digital My Book World Edition
I have the same drive. It works great with windows XP but with Windows vista has difficulty seeing this type of drive and keeping the connection once it is established. Take it back if you have windows vista and then search for which 1TB drives work well with windows vista. It really has problems with windows vista 64bit. I was able to finally see the drive when I was using photoshop file/browse/network... then I dragged the shortcut Icon to my desktop and access the drive that way from that point on. Mine stopped completely tonight... I think the power cord went bad or something.
Jan 04, 2009 | Western Digital My Book World Edition 1TB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
9,324 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
