Question about Samsung Office Equipment & Supplies
Samsung CLP 510 - won't print on photo paper.
We have a CLP 510 and we can't get it to print on coloured paper. . the ink smears and collects on a drum or something and goes onto the next paper. we are totally unable to get anything like a glossy photograph. or even slightly glossy paper. It prints good colour on flat paper. Recently we tried a premium paper for colour copying and printing and it just didn't take. Paper was made by storaenso and sold from Office works. My friends hp copier of similar size had no problem and did a lovely job on the exact same paper. Can you help
  • sbholt Aug 31, 2008
    I can't find a special paper function on the menue ?
  • Samsung Master
  • 6,487 Answers
You may want to check this link for this concern http://www.dunfield.com/clp510/
Hope that helps.........
Posted on Aug 31, 2008
    Sergeant:
    Champion:
  • 236 Answers
Use the cartridge cleaning program in the program that came with the printer.
this should clean them and probably stop the ink bleeding
do not rate until satisfied.
  • 928 Answers
When you do a print you have to select the option to print on glossy paper. This is because when a printer prints on glossy paper it has to print slower and the heater is heated to a temparature that is higher than regular paper so the ink will dry. You can do this in your print settings. On a document when you print you will get print options you can change the setting there.
  • Thomas Lim
    Thomas Lim Aug 31, 2008
    Go to Print setup then properties to the right of the currently printer.
    Select MEDIA if you dont see paper type
    Sergeant:
  • 241 Answers
Have you changeed the PAPER type to (specialty or card stock) this always work for me. Your printer will have these setting
  • 3 more comments
  • Jayson Brollini
    Jayson Brollini Aug 31, 2008
    You can access them through start+control+printers
    from there just right click the printer and go to the menu from here you can save the settings so you do not have to keep changing every time you print
    Also make sure to run a (clean and alignment ) under your menu Maintanances
    GOOD LUCK AND PLEASE POST FOR MORE HELP
  • Jayson Brollini
    RATE YOUR FixYa ExpertKindofcheap
  • Jayson Brollini
    It is under PAPER TYPE
  • Jayson Brollini
    go to advance printing options
  • Jayson Brollini
    This should help you
    If not your printer cartridge head is dirty (just from ink) but do that last because you can do that through the settings.
    I am not sure if this pinter use a cartridge
    > if you have no success with any of this then pull it and carefully
    wipe /pat the bottom of the CARTRIDGE Printer Head. Be careful not to
    touch the other parts of the cartridge
Samsung CLP-310 Colour laser doesn't print properly
This is not a driver or Windows issue, has the ink cartridges been changed recently, it sounds like the the paper is not being magnetically charged before the ink, unplug the power cord for 30 sec plug back in and try printing again
Nov 07, 2013 | Samsung CLP 300 Laser Printer
Smearing of printed image in color printing mode
many times this problem is caused by the type of paper being used, especially with photos, try a different paper, or change the type of paper in the print box when you try to print. the amount of toner used is determined by the paper type. if you are printing on glossy paper you might get the smearing if you didn't tell the printer to print on "glossy" Anyway, this is most likely where to problem can be solved. good luck
Mar 24, 2011 | Samsung CLP 300 Laser Printer
Ink from smearing all over my papers
Using original cartridges won happen like this.
May 30, 2010 | Canon Pixma MP450 All-In-One InkJet...
How to refill the cartridge for Samsung clp 510 laser printer
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 18, 2010 | Samsung CLP-510 Laser Printer
Samsung clp-510
may be the drum of your laser cartridge must be end of its life orwaste toner collection unit must be full.
Aug 07, 2008 | Samsung CLP-510 Laser Printer
Getting error message on samsung clp 510 printer
yes refilling will solve the problem.but you have to change the green colour small chip on the side of the toner to make it work,as the new chip will be detected as new toner in the printer.
Jul 28, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Jul 14, 2008 | Samsung CLP 300 Laser Printer
Ink issues Samsung CLP-510
Some paper tints can cause problems with color images, so make sure that you're using plain white paper, not another color such as beige, yellow, or blue. Even an off-white shade can affect your colors.
In addition, paper type can slightly influence your ink color. Highly absorbent papers can draw in the ink so quickly that the printed image may seem dull or a little washed out. If this is the case, try a coated paper that is specifically intended for color printing. If you're printing those important family vacation photos, use a good-quality glossy paper.
If your colors are way off, you may be running out of one or more ink colors. For example, blue and yellow are mixed to make green, so if your grass seems blue rather than green, you may be running out of yellow. Check your ink cartridges and replace any that are low or exhausted.
Thank you, & post back if you still need assistance.
May 07, 2008 | Samsung CLP-510 Laser Printer
Colour print smears
Please remove imaging unit and transfer belt and make sure no paper is lodged above the transfer belt (ITB)
Dec 01, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP-510 not printing?
Most probably you are using an USB cable that is either too thin (cheap cable) or too long (beyond 6ft.).
Oct 22, 2007 | Samsung CLP-510 Laser Printer
164 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
