Question about Philips Audio Players & Recorders
Philips FW340c mini hifi system. Can hear sound on the headhone 3.5mm socket but not on the speakers when the headphones are removed. I dont have a diagram so Im having trouble tracing the circuitry. Peter Miller
  • 319 Answers
SOURCE: i have a creative sound
No. Phone socket cuts out speakers when headphone jack is inserted
Posted on Apr 24, 2008
  • 111 Answers
SOURCE: Toshiba satellite laptop
I think the problem is in your Headphone jack.
Hope this helps.
Posted on Apr 29, 2008
robotek
  • 1512 Answers
SOURCE: headphone socket
Hi twelvetwelve
Are you able to get access to the rear of the socket and use a small screwdriver to push out the parts of the plug that have come adrift inside the socket? You may have to actually remove the socket from its PCB to get access. If you cannot remove the offending parts, then you may have to replace the socket. There is not alot more that you can do unfortunatly.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
  • 1550 Answers
SOURCE: Due to moving I had
The problem lies in amplifier .
Posted on Oct 31, 2008
  • 34 Answers
SOURCE: Sound
I have heard of this problem before. If the red light is always on the headphone jack might think there is something still in place. You could try blowing any dust out with a can of air before you perform and archive and install.
Posted on Jan 25, 2009
Why does my lowrey organ not make a sound after I have switched it on?
This is a generic answer for this kind of question.
When there is no sound
Check the obvious.
Is there a light on the organ indicating it is on?
  • Plug it in to a known working wall socket, switch on at the wall
  • Switch on at the organ, check light
  • Very old keyboards need a voice to be selected!!
  • Turn master volume up
  • Turn any other volumes up
  • i.e. lower manual volume
  • upper manual volume
  • swell pedals down
Sometimes a sustain pedal plugged into a volume pedal socket will mute the output, check this.
Headphones out, most headphones will turn speakers off, sometimes the headphone switch can be dodgy, work the headphone plug in an out a few times
There maybe a switch that turns off the speakers, look near the output sockets
Software volumes up, check display, if any.
MIDI instruments, check local control is ON
Still no sound?
Can you hear anything from the speakers?
Hiss or hum usually means the speaker is ok
Total silence may indicate speaker failure, but only if there is one speaker, as in older home organs, or smaller keyboards
Try headphones next, TURN Down master volume first just in case!
If there is some sound, very quiet and gross distortion then possible power amplifier failure.
If your instrument has any kind of line out as well as a headphone jack, try these.
The line output will likely be a pair of phono sockets,like you have on HiFi equipment, 1/4 inch, 6.35mm jacks, like the bigger headphone connector, a 3.5mm socket like the smaller headphone connector, or even a DIN connector on older equipment.
Connect these to the aux (or Line or CD) input on your HiFi, guitar amp or similar. (some times these outputs will drive headphones, usually you will only hear anything in the left side). If this works then it is very likely the power amplifier.
Further tests on MIDI equipped keyboards would be to see if the MIDI does anything.
If MIDI out works and there is no sound, and MIDI in makes a sound this points to local being off, buried somewhere in the menu will be local on or off, make sure it is on.
If MIDI out doesn't work then the failure is likely to be internal power supply or something else critical (not nnecessarily major).
Power amplifier failures in newer, low power, keyboards are often the power amplifier chips (i.c,s), older amplifiers may have just blown their fuses but one or more output transistors may have failed.
Cost of repair will be down to the time it takes to get to the fault, taking these to bits and putting them back can take a lot longer than the repair.!
Hope this helps, Chris the Fader
Aug 28, 2016 | Music
How do I get better sound with my roku tv
The speakers on a lot of TVs are not very good quality and seem to rely on owners providing their own audio solution. You have a couple of options if the TV speakers are not up to expectations.
1. Sound Bar - available from Audio/video retailers/Amazon.com etc.
2. If you have a hifi system or Ipod dock in your house with a 3.5mm jack input, and you TV has a 3.5mm jack headphone socket then you could connect it up and this will use the speakers on your audio equipment which will improve the output.
Dec 01, 2014 | TCL 55" Roku Ready Tv 55fs4690
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
I have a CD Stereo system SA-AK17, 120V, 145W, without speaker. I provided 2 speaker with the brand of Technics, input 200W(.music), 100W(DIN) each speaker. I bought Audio wire and connect speakers...
Some stereo system have the ability to switch off the speakers when playing via headphones. In others the headphone socket itself does the switching. However headphone sockets can become faulty and when the headphone plug is removed it doesn't restore sound to the speakers. It's very easy to fix this, with a check that the contacts are not bent out of place. Or you can rewire a new headphone socket, making a note of the wire connections before you replace it.
Sometimes it is quite difficult to get the speaker cable to make a good contact with the speaker sockets. You should check that they are making contact.
To test any loudspeaker just connect a 1.5 battery for a short time across the disconnected speaker. If working the speaker will pop!
As the sound is going to the headphones the amp seems to be OK and one of the above options should correct the problem.
Oct 27, 2017 | Panasonic SC-AK17 Shelf System
I no longer have the audio cables provided with the speakers. I bought a new rca cable and tried to connect the speakers to my laptop. however no sound comes out. help. could it be that i dont have the...
Hello, have you got any headhones? If yes, then plug them into your laptop and play a cd or run something from youtube...can you hear any sound?
Do you have a portable radio or mp3 player? If yes, plug your speakers into the earpiece socket on either one of them...you will be able to get sound out of them if they are working. This is a good test of your loudspeaker system as the output from a radio or mp3 player is of a similar level as that of a pc or laptop soundcard.
Let me know how you get on,..and don't forget to vote!
Regards,
nicaam49
I
Jan 26, 2011 | Altec Lansing MX5021 Computer Speakers
How to i connect my bose companion 2speakers to my computer and get sound
hi, first Identify what computer you have. Is It A Mac or PC?
If it is PC
There should be 2 small 3.5mm coloured sockets on the back,front (or both ) of the main box (tower/desktop unit). You should find that they are coloured Green and Red. Green is for sound output (Headphones/speakers or hifi) and the Red is for sound input or Recording. Used for things like microphones. Some will accept line sources such as mixers and Ipods pr cassette players, but please check your sound manager, mixer settings in your opperating system to make your you have an adjustable input setting for Mic and Line input attenuation as not all do and you may end up with a distorted mess. You may also find there is a small diagram of headphones or a microphone to indicate sound "in" and "out" ports.
If you have a mac
Appart fom me being envious :-) there are two sockets. On laptop types, on the side or on the tower types on the front,back or both. They have a diagram of a microphone and headphones. Hadphones is for audio output to headphones, speakers, hifi, dj mixer. The Microphone is a sound input. Please read above for microphone port usage. Hopefully this answers your question. Please also bear in mind that if you have no sound once plugged in, you may need to adjust the audio properties in the system in the system and/or program you may be using
Dec 29, 2010 | Bose Companion 2 Series II Multimedia...
Yamaha RX100bike in 4 gear modified it 5 gear
i have universal remote control philips , i need a program code for mini hifi philips
Feb 14, 2009 | Yamaha Digital Sound Projector YSP-800S -...
Can get mini hifi system to work with tv and dvd player. How do I connect them?
To be honest mini hifi`s arent the best to be using as speakers for your tv.
But you connect them using RCA phono cables.
Its a lead with a white and red connector on each end.
Lokk up RCA phono cable and you`ll understand what i mean.
You plug that into your tv then to hifi,
May 31, 2008 | Philips Audio Players & Recorders
90 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
