Question about SanDisk Sansa e250 MP3 Player
Sandisk sansa mp3 player
My battery charging screen wont shut off it won,t go back to the main menu after charging it , the blue circular arrows keep going around
Ok , what you do is you pry off the bottons on the front, then there should be a screw. unscrew it. then youll see the screen thing. there will be two metel circals, one of them is probably dusty, just wipe it off and put every thing back together, the buttons just snap back on.
Posted on Sep 03, 2008
Sansa e260 mp3 player won't charge
Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery
Also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring problem) and put the back on.
Apr 03, 2010 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
My m3 player froze while charging and now it wont turn on
I held it in the off position while at the same time pressing the menu button....it shut off, then I restarted it. It will repair the media itself.
Jun 26, 2009 | SanDisk Sansa e250 MP3 Player
Sansa 260 Won't Let Me Navigate Back to Main Menu
The power button is also the Menu button - click and release once while the player is on, and see if it gets you back to the main menu. Or press the left arrow key and see if it will get you back to hte previous menu.
-Tha Mp3 Doctor
Feb 21, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk sansa clip mp3 shuts of and wont turn back on...
You can set the timer under Auto Power Off and Sleep settings to turn off the Sansa
player automatically when it is playing for a certain time.
1. Press Menu button to return to the Main Menu.
2. Move to Power and select it.
3. Select Auto Power Off or Sleep.
-Tha Mp3 Doctor
Nov 06, 2008 | SanDisk Sansa Clip MP3 Player
My player is messing up
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 12, 2008 | SanDisk Sansa e260 MP3 Player
Problem with sansa e260
that happens to me too. i think the problem is that your computer can't like, sense that it's plugged in, so your battery's dying out, and the computer wont charge it
Mar 24, 2008 | SanDisk Sansa e260 MP3 Player
Sansa wont turn on :(
Try taking it back or calling the company where you got it from.Unless of course you got it off of ebay then contact the seller.
Mar 15, 2008 | SanDisk Sansa e270 MP3 Player
Frozen screen
All you reaaly have to do is let the battery run out. Then once the mp3 is dead, charge it. The screen should be unfrozen.
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk sansa mp3
k, so now the SanDisk sansa m240 1GB mp3 player, when you turn it on, it freezes. I have tried to change the battery and everything and it still wont work. What is happening here? others that have had the same problem. I researched this online and found out that there was a rather large bad batch of these mp3 players shipped in December. they suggest calling sandisk tech support at 1-866-726-3475 for a replacement and getting a RMA number or going back to where you bought it and exchanging it.
Jul 09, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
