Brivis ducted heating Multiplex(MPS) ME 20i with fault code H01 #56
3 Suggested Answers
SOURCE: i have a brivis buffalo
u can down load a manual from brivas it has the trouble shooting page in the PDF
Posted on Oct 07, 2008
ginko
  • 19396 Answers
SOURCE: Hi i have a brivis buffalo set up for ducted
Hi.
Ceck if there is spark.
If there is no spark, then the igniter may need replacement. Testing is done reading volts.
If there is spark, then either valve coils or flame sensor may be causing the problem.
Valve coil can be tested reading Ohms at coil contacts (power off first). If the coil reads infinite Ohms, then it must be replaced.
If coils are good, then the flame sensor must often be replaced. This is more difficult to test.
In some case the valve may be mechanically faulty (stuck), or wiring and control board may be responsible of the problem.
Posted on Aug 16, 2010
Brivis multiplex he20e
MPS HE20E is a gas heater. So the unit should need a pilot to be re-ignited. This will happen automatically once you press the ON button on the controller. Assuming the gas supply is normal this should happen immediately. The unit attempts re-ignition 4 to 5 times but if the pilot does not turn on it will display an error code on the controller. Take extreme precautions when dealing with gas appliances. Make sure you call a technician if unsure.
Aug 21, 2014 | Heating & Cooling
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Brivis heating
sounds like an over heat safety sensor is faulty,or blocked ducts to have to much heat buildup in furnace, best advise have a techie look atbit
May 05, 2013 | Heating & Cooling
Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
May 31, 2010 | Heating & Cooling
Brivas ducted heating not firing up. Gas supply ok electic supply ok. Spanner symbol on screen and Error 62 Model ME 20 E
Hello, We have Brivis Me20 gas ducted heating. It suddenly stopped working and gives error #60. Sometimes after pressing reset several times it fires up for a short period then fails again. Any ideas what might be wrong?
Thanks,
J
Apr 30, 2010 | Heating & Cooling
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Cannot start the Brivis heating device
I have been without heating for the past month since the fan motor in my ducted gas brivis heater filled the house with smoke.
The guy replaced the fan motor, and then it had the same symptoms as yours.
After a month of various tradesman trying to work it out, it has come down to the "thermal switch" within the unit.
Jul 29, 2008 | Heating & Cooling
Heating & Cooling Logo
266 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
