Question about Honeywell Heating & Cooling
Honeywell fireplace wont start - Honeywell Heating & Cooling
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Webpage for manufacture troubleshooting page.
Posted on Sep 01, 2008
Switch on wall fireplace with Honeywell control SV9403, pilot does not turn on even there is current flowing into the controller device.
Good Evening. Your fireplace is equipped with a smart valve (SV) to which the valve itself acts as the control. This unit has intermittent pilot or hot surface ignition. Can you clarify to me which ignition this unit has?
Dec 30, 2013 | Honeywell Programmable Thermostat Heater
Fireplace remote control no longer works correctly
To re-sync your Honeywell 8220 transmitter to the valve: Turn the Local/Remote switch on your valve to Local. Then switch it back to Remote. Within 10 seconds of switching it to Remote, you need to press the Flame button on your transmitter. This will re-sync your transmitter to the receiver in the valve. Replacement transmitters and valves are no longer available for this system, they were discontinued by Honeywell and they are completely out of stock. Monessen Hearth Systems (now owns Majestic, Vermont, etc) has a retrofit kit with a new valve, pilot assy, and remote for these old RF units. (expensive, but cheaper than a new fireplace). FYI, aftermarket remotes are NOT compatible with this Honeywell system.
Nov 24, 2012 | Televison & Video
I have a Vermont Castings gas fireplace and a honeywell remote control. Recently the control developed an issue where it will not shut the fireplace off. I have to do it manually. It still turns it on...
It could be that your transmitter is bad. You may want to try to re-sync the remote to the fireplace. Slide the Remote/Local switch on your valve from remote to local, then back to remote. Within 10 seconds press the flame button on your transmitter. This will establish a new frequency connection between your transmitter and valve. Good luck!
Nov 14, 2012 | Honeywell Televison & Video
I have the honeywell round thermostat #, CT87K. I am trying to wire it up to controla gas fireplace. I have two wires coming from the fireplace I have tried every combination of wires. it will turn the...
That Thermostat will not work on a gas fireplace. The voltage is all wrong. You need a thermostat that will work on millivolts generated by the thermopile on the pilot assembly of the fireplace burner. It will only turn on, because you opened the circuit. It will not turn it off automatically or at all, for that matter.
Better yet, why don't you purchase a Wireless Remote Control that has a thermostat built-in. It's a multifunction remote that will work up to 25 feet from the fireplace and comes with a wall hanger. The SkyTech # 3301TH, should work well for you. http://www.skytechsystem.com/
Feb 17, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
I have a honeywell remote control that no longer works. As in it won't make turn on/off the fireplace. I did replace the batteries. Where do I get a new one?
I happen to have one from my fireplace..same as you use. No longer need it since had to replace my entire fireplace box. Let me know if you wish to buy it. Say $100 total (includes s&h for ya too :)--Mike
Nov 15, 2010 | Honeywell Televison & Video
GAS FIREPLACE
Yes, hopefully changing the thermocouple (skinny sensor) or thermopile(fat sensor) would do the trick.
Start with these fairly inexpensive repairs first.
Unfortunately if the honeywell valve is bad a new one can be expensive.
Also it is hard to order parts from Majestic, they just went bankrupt, not to long ago and Martin is taking them over. You might look for your valves model# and check online for other suppliers of that model# or ask for a compatible Direct Vent gas valve that's not as problematic. (eBay and HVAC dealers, etc.)
FYI:
You said it's been about 5 years, you might decide it's less of a hassle to have new gas fireplace installed. Martin and Empire are probably two of the best, with 5 year parts and labor warrantys.
Hope you find some success in your endeavor.
Dec 10, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
333 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
