Question about Motorola Mobility RAZR V3c Cellular Phone
Cant connect bluetooth to my phone - Motorola Mobility RAZR V3c Cellular Phone
  • Terra Ditto
    Terra Ditto Aug 31, 2008
    it look for device
  • masadler1 Nov 06, 2008
    I have a nextel rim7520 blackberry and it will find my h500 bluetooth but won't pair with it. I've tried 0000 for pass key but doesn't help
How can you help me with my problem
Posted on Aug 31, 2008
Cant receive file to my e2222 samsung phone.
I have check all the possible solutions for this problem bt m nt able to get rid of it ... Im not able to receive file nor able to send file I cant connect to any device from my Bluetooth.....
Oct 01, 2012 | Samsung Chat 222 Plus
Cant pair bluetooth with other phones
check the bluetooth version of your phone..
some phones can pair bluetooth connections if its version are not compatible with each other.. example: bluetoooth version 2.0 cant search/find the bluetooth version 2.1. vice versa..
Mar 17, 2011 | LG Cosmos VN-250 Standard Battery and...
My speaker have water damage, i can hear but they cant hear me, can i use blue tooth
Hi, a blue tooth device would allow you to hear and speak through it so it should solve your problem.
the only problem you may have is if the water damage has causes damage to bluetooth inside the phone, try choosing bluetooth on your phone and see if you can still do a search and connect with another phone, if you can still connect to another phone to say send music or picture via bluetooth then this would suggest your bluetooth is fine and using a bluetooth head set will solve your problem and allow you to use your phone again.
if you cant connect to another phone via bluetooth then the chances are it wont pick up the bluetooth head set and you would be no better off
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 13, 2010 | LG enV3 VX9200 Cell Phone
Problem w/ connecting h680 to EnV2
just get your bluetooth in pairing mode (steady blue light) then have your phone find the device then connect them when they ask you for the pass code its 0000 if your bluetooth is connected to a different phone you must disconnect it and if it doesnt work and you tried your best try turning the phone off then try it again sometimes this does the trick
Mar 29, 2009 | Motorola Mobility H680 - Headset -...
I cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
or
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
Mar 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Phone can't pair with bluetooth but is bluetooth compatible.
well whats the problem you cant connect your bluetooth to your phone or is it not comming up on your phone? did you pair it correctly?
Jan 29, 2009 | Nokia 6133 Cellular Phone
Bluetooth wont stay connected
probably a hardware issue on the phone itself...
i would call up lg support first ask them why is this...
bluetooth does have a 10m range and connecting a bluetooth headset shouldnt be as far as 10m
Aug 21, 2008 | LG Shine CU720 Cellular Phone
Cant pair my bluetooth
To identify where the problem is, try connecting another bluetooth device (like another phone, or a bluetooth headset). The other device will most likely connect. If it does, try contacting the manufacturer of the dongle, they will probably have a simple solution to fix it.
If it does not connect to another device, try deleting the bluetooth devices stored in phone (especially ones you dont use, but you may need to delete more/all depending on the situation) and add then. This fixes connection issues the majority of the time with very little trouble since rebonding what you need later is a simple task.
May 17, 2008 | HTC PPC-6800 Smartphone
USB connection
try and use bluetooth. you can buy a bluetooth dongl for your pc if you cant do connection via usb cable.
Jan 25, 2008 | Sony Ericsson K750i Cellular Phone
Motorola Mobility RAZR V3c Cellular Phone Logo
13 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
