Question about Canon PowerShot SD600 Digital Camera
Lens error,restart camera
Lens will not close
  • 10 more comments
  • boots08 Oct 03, 2008
    my camera, Canon Powershot SD600 Digital Elph, lens will not close. when I power on the camera it shows my welcome picture on the LCD screen then beeps 3 times and message "lens error restart camera" appears on LCD screen. How do I restart the camera???
    Thanks...
  • smileys Oct 03, 2008
    my camera, Canon Powershot SD600 Digital Elph, lens will not close. when I power on the camera it shows my welcome picture on the LCD screen then beeps 3 times and message "lens error restart camera" appears on LCD screen. How do I restart the camera??? Thanks...
  • esharoky Oct 07, 2008
    The lense on my PowerShot SD870 will not close. When I power up, everything is fine, there are no error messages. I can still take photos but the will not focus and are all blurry! How do I get it to close!?
  • juanabanana Oct 07, 2008
    When I turn on my camera it says lens error restart camera... so i dont know how to retart a camera
  • mickthompson Nov 28, 2008
  • sitibit Jan 04, 2009
    my camera is doing the same thing as everyone else posted. (turning on waiting 5 seconds to beep a few times and go black reading, "lens error restart camera." only im tapping, hitting, twisting, shaking, practically beating my camera up, and im still getting NO RESULTS! this is so random, my camera never made grinding noises or had ANY problems before. HEEEELP!!??!?
  • luciani Jan 08, 2009
    This is Bull! I have the same problem. Lens Error! The camera was never dropped or handled improperly. What to do?
  • kdihope Jan 09, 2009
    I have a Canon Elph SD600. It is reading "lens error, restart camera" with the lens locked in the OUT position. I have taken off the cover and cleaned all around the lens as gently as possible. I have tried to sort of work the lens back and forth to loosen it and no luck. The lens doesn't even attempt to do anything when I power it up, nothing. Please, help!!!
  • Omar SERY Feb 15, 2009
    my camera turns on it shows the cannon screen then it goes black and says lens error restart camera and the lens are Way out i tried taking out the battery and the memory card but nothing is working what do i Do?
  • Anonymous Feb 27, 2009
    So when i got out of my car tonight the i forgot the camrea was on my lap and it droped on the concrete and when i turned it on to see if it was broken it said "lens error, restart camera" How do you restart the camrea
  • Anonymous Mar 08, 2009
    I have the same lens problem but the lens is in. Lens error, restart camera
  • Anonymous May 08, 2009
    Canon 9015 up to restart tricks - yeah gave it a bit of tapping
    and thumping - bit of cajoling and eyeballing and it starting
    working, going with the grit theory - John Bethune
My Camera: Canon PowerShot SD770 IS Digital Camera
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god.
Posted on Nov 30, 2009
I had this problem of the lens being stuck all the way out on a Canon Powershot SD600. Upon pressing the on button, the camera would make an error sort of buzzing and clicking. The screen would turn on and would briefly display lens error, restart camera and then shut off. I thought it was hopelessly broken. I came to this site and tried the suggestion of gently but firmly pushing the lensback in while turning on the camera. I tried that and it didn't work, nor do I recommend that. The amount of pressure needed to try and force the lens back in is surely such as playing with disaster.
I tried the other recommendation of working the lens by gently twisting it back and forth and rocking it gently side to side and periodically tapping the side of the camera against the palm of my hand particularly with the lens facing downward so as to dislodge the debris; sending it out in the reverse direction it came into the camera.. This seem to loosen the tightly locked lens. I continued gently working the lens as to pulverize/dislodge the dirt or sand particle caught in the moter or lens mechanism. All I know is it tworked.
Posted on Jan 03, 2009
  • dagermike Jan 03, 2009
    This method fixed the lens problem. The lens retracted on its own and the camera now works normally again.
Who can fix this problem?..
Posted on Oct 03, 2008
I had this problem with my SD600-- after a couple of days of making a grinding sound when the camera powered on and off, it finally stuck with the lens fully extended. When I turned the camera on, it waited 5 seconds, then beeped, displayed "lens error, restart camera" and shut off.
After much cajoling, shaking and knocking, I finally tried the following: turned the camera on, and gently but firmly pushed the lens itself back into the camera. It's back to the old grinding when opening and closing, but it still works.
Good luck.
Posted on Oct 31, 2008
The method of gently nudging the lens bach and forth was the way to go. I had to open the battery door so as to control the powering off of the camera. When the battery came out, it stopped the camera from shutting off and when I put the battery back in, the camera tried to power on again quicker. it gave me several attempts at freeing the lens. The way to do it is to gently "pursuade" the part of the lens closest to the camera. Not the smaller outer part. This lens getting stuck happened when the battery ran out of power with the lens in the out position. Good luck. This was much better then the time I sent it out to be repaired. This would have been a costly repair. Thanks FixYa, and you too dagermike.
Posted on Mar 08, 2010
The method of gently nudging the lens bach and forth was the way to go. Is true it WORKED for me.
Posted on May 02, 2010
Lens error restart camera canon SX10IS
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 23, 2013 | Canon Cameras
Camera will not turn on...we receive Lens error restart camera
i have a polaroid one and it also says error and i do not know how to restart it or anything and the camera will not close
Jan 09, 2010 | Canon Photography
"Lens error, restart camera." The lens won't close,
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to corr
ect it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 04, 2009 | Canon PowerShot A560 Digital Camera
"LENS ERROR, RESTART CAMERA", THIS IS NOT WORKING.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Feb 20, 2009 | Canon PowerShot A540 Digital Camera
Lens wont close.
did you try and take the battery out and outting them back in
might be worth a try
Feb 08, 2009 | Canon PowerShot SD850 IS Digital Camera
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Apr 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD600 Digital Camera Logo
4,766 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
