Question about SanDisk Sansa e250 MP3 Player
Sansa e250 it wont turn on, i charge it and then i try to turn it on and the circle turns blue but thats it cant get anything on the screen and it wont play music
  • kurtz41 Aug 31, 2008
    can anyone help
Hold the power button for a SLOW 20 sec, then power up with NO PROBLEM!
Posted on Sep 01, 2008
My m3 player froze while charging and now it wont turn on
I held it in the off position while at the same time pressing the menu shut off, then I restarted it. It will repair the media itself.
Jun 26, 2009 | SanDisk Sansa e250 MP3 Player
The screen on my sansa e260 wont turn on
hold down the power button for 15 seconds and it shoud reset the whole player
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E250 won't turn on after trying to plug it into an an ipod docking station my sansa mp3 player wont turn on or off the only way i can get it on is to plug it in to charge. and i cant take it to work...
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
Jun 27, 2008 | SanDisk Sansa c240 MP3 Player
Sansa e250 won't turn on
well , when you have something on a charger and the end that goes into the wall is unplugged and the other end is plugged in to whatever needs to be charged ... it drains the battery out and thats probley what happened to u. i have one 2 and you do not want to drop sansae250 ... i woner how you get videos and pictures on it .
Alyssa , 9 ♥♥♥♣♦
Feb 02, 2008 | SanDisk Sansa e250 MP3 Player
Jan 31, 2008 | SanDisk Sansa e250 MP3 Player
Wont connect to my computer
If it still has power, or charges, plug in the mp3 player then turn it on, then turn it off by holding the power button, once it is off, switch the hold on then press and hold the REC button until a black screen turns on saying that it is connected, your PC should then recognize the mp3 player as 16mb removable device, now open notepad, DO NOT WRITE ANYTHING on the notepad and save it as format.fmt and save it into the mp3 player and then safely remove it, the mp3 player should format. If the above does not work please reply with what you see inside the 16mb drive.
Jan 21, 2008 | SanDisk Sansa e250 MP3 Player
The Screen Stays black and the ring turns blue and thats it
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e250 MP3 Player
try holding the menu button until it turns off then leave it off for around 30 minutes then try to power it back up. If it still wont turn on perform recovery mode and upgrade the firmwar eof the player if havent done so.
Aug 27, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
