Question about Dell Inspiron 2200 Notebook
Dell Inspiron 2200 maximum display resolution
Is there any driver I can install for increasing the default 1024x768 max limit? TIA.
  • dooyu223 Sep 01, 2008
    Thnx for the response, bunnydawg! I've been to that Dell support site but I'm not sure which driver (if any) may actually increase my monitor max resolution. Should I install the listed Intel chipset driver or video driver or something else? Thnx!
    Thnx for the quick response, Bunnydawg! I've been to that Dell support site but I'm sure which driver would actually increase the resolution limit on my monitor. Should I install the Intel chipset driver, video driver, or something else? Thnx!
    Brigadier General:
  • 5,158 Answers
  • Roberta Smith
    Roberta Smith Sep 01, 2008
    video driver would be the best solution. that screen may not be able to accept a higher resulotion.
    Best bet is to download the manual while you are there and read up on it.
    Be sure to rate the solution.
    Take care
    Robert
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Jul 14, 2011 | Televison & Video
Have bought Dell Inspiron 15 R N 5010. But the picture quality is really poor even after 512 mb graphic card. What to do.
Try increasing the screen resolution to maximum and colour quality to higher available. See whether proper driver has been loaded. If yes try reloading it and restart and check it
Sep 05, 2010 | Dell Computers & Internet
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I want to now which ram is used for dell latitude 640, latitude 520, latitude 430, latitude 420 and inspiron 2200 is it ddr2 or ddr1 and max capicity for upgrade
Here are the max memory and speeds:
Lat C640 is Max 512M per stick DDR-266 (PC2100) or DDR333 ( PC2700 ) for a total of 1024 Meg
Lat D520 is either 2 or 4 Meg total. DDR2-667 ( PC2-5300 )
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.Maximum memory for systems with the Intel 945GM chipset is 4096MB, maximum memory with the Intel 940GML chipset is 2048MB
Lat D430 has only slot with a Max of 1 Meg. You can use DDR2-667 (PC2-5300)  or DDR2-533 (PC2-4200)
Lat D420 is a max of  1.5G    . Use 1GB DDR2-533 (PC2-4200)
Inspiron 2200 is one slot with a max of 1280 Meg. recomended is 1GB DDR-333 (PC2700)
Here is a link to find almost any memory you need:
http://www.crucial.com/index.aspx
NOTE:
When mixed speeds in the same PC, the memory will run at the slowest speed installed or the highest speed allowed by your system, whichever is slower.
Good Luck
Dec 17, 2009 | Dell Latitude C640 Notebook
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
The display limit is determined by the LCD design. IN this case, you have an XGA LCD resolution 1024 x 768 pixels. This is a hard wired resolution and can only be changed by exchanging the XGA LCD for a higher resolution one (SXGA or higher, likeky not an available option for an Inspitorn 2200)
http://compreviews.about.com/od/multimedia/a/LCDSpecs.htm
Apr 19, 2009 | Dell Inspiron 2200 Notebook
I cannot install Dell E196FP monitor properly - resolution poor
The problem is you don't have the display adapter driver installed (Video Card)
You can net that driver at support.dell.com
Jan 25, 2009 | Dell E196FP 19" LCD Monitor
High resolution display drivers needed
You will need to connect an external monitor that is capable of a higher resolution. Sound like the native resolution of the LCD panel in the notebook is 1024X768, not uncommon for 15" laptops.
Jan 10, 2008 | Computers & Internet
Anyone know a way to increase the resolution past 1024 x 768?
First, you might want to check what the maximum supported resolution of your monitor is. You can do this by looking it up on the internet or referring to the owners manual. If you cant find that information, in your graphics properties in Windows XP, click the advanced button beneath the color settings and click the monitor tab. Make sure the model listed under 'Monitor Type' matches the monitor you have. If it does, see if the 'Hide modes that this monitor cant display' box is checked. If so, the maximum resolution is limited by your monitor and you may have to upgrade the monitor to go any higher. If the model does not match, you can try the following: click Properties->Driver Tab-> Update Driver and either load the correct ones from the manufacturers web site or use one of the Standard Monitor types provided by the windows Driver library. Be warned though: If you select a standard type with resolution higher than your monitor supports, it will not display correctly at settings higher than 1024x768, and you may have to wait for windows to change the resolution back. Another thing you can try is unchecking the 'Hide modes that this monitor cant display' box, clicking ok, and setting the resolution to something higher than 1024x768, but the same warning applies! If it does not display correctly than you know for sure that the monitor is the limiting factor.
Nov 09, 2007 | Sharp LC 28HM2 28 in. Flat Panel LCD...
Cant get 1280x1024 when connected to laptop
the only way you may get it to work is if you use the monitor a secondary device and also use the notebook monitor as well. But the problem may also be the vga connector converting the signal, as you may have to have a DVI connection on your monitor to obtain widescreen resolutions.
May 28, 2007 | LG Flatron L1710B 17" LCD Monitor
Dell Inspiron 2200 Notebook Logo
98 people viewed this question
Alun Cox
