Samsung Digimax A400 Digital Camera
Problem for Samsung Digimax A400 Digital Camera
Camera shuts off by itself
By Quack - usenet poster on Sep 12, 2005
I just got a samsung a400 camera ,I only used it a few times i went to turn it on and it shuts off by itself.I changed the batteries in it and it is still doing it.I am wondering if any one else has had this problem.This is my first digital camera and wondering if it was a wise choice to buy a samsung.
Same Problem
Dec 31, 2007
-   have the same probem..my old batteries worked til now, tried new sets but they stil dont work. it really shuts off halfway to opening the shutter..could this be a virus?-   Guest
Solution #1
posted on May 31, 2006
Somewhat Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1893 votes
Are you certain the batteries are good and fully charged. They do wear out eventually.
Hopefully it's not a jammed lens causing the problem. Does the display come up with an error number or maybe even "lens error" before switching off? If it does it will mean a trip to the camera doctor.
How far are you actually getting with the switch on? Try switching to view picture instead of the shoot mode. This consumes less power and if you can see the last picture you took on the LCD or even a flash of it before closedown I'd put my money on bad batteries.
Make sure the battery ends are clean and the camera battery contacts aren't corroded or dirty. It's sometimes amazing how trouble a little dirt can cause.
BMW
Comments:
May 31, 2006
- If none of the above works the camera should still be under warranty. Take it back for a fix or replacement.
May 31, 2006
- Rat's one more thing. What type batteries are you using? If you are using cheap alkalines it's possible they don't have enough power to fire the camera up. Spoil yourself and buy a set or two of Nimh rechargeable batteries the higher the MAH the better. I use 2600mah batteries and they last for hours none stop. That also means you'll need a good charger but it'll save you a fortune in the long run.
BMW
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 29, 2007
Very Helpful)
mpc855t
Rank: Apprentice
Rating: 87%, 3 votes
Does your camera work with regular AA alkaline batteries ? I'm having a similar problem, my camera won't work with 1.2V NiMH rechargeables, but it works fine with 1.5V regular AA alkaline batteries.
Was this helpful?
Yes
No
Popular Solutions for Samsung Digimax A400 Digital
Questions and Unsolved Problems for Samsung Digimax A400 Digital
Do you recommend Samsung Digimax A400 Digital Camera?
Answer
Answer
camera will power on, however, when I press the button to take a picture the green light comes on... (More)
Answer
lost instal disc for samsung a4 digimax camer,cant upload pics to pc..need to download the softwear... (More)
Answer
date & Time settings keep reverting to 2004 default. how do i fix it?
Answer
when i turn it on it comes up standby start shutter how do i get this to open the shutter
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung Digimax A400 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
