Question about Gateway 3522GZ Notebook
Gateway 3522GZ display
Display went dark on startup, the video is there, but so dark it is only visible isn a darkened room. Remote monitor works fine. Power down, power up, unplug plug in hard drive, nothing helps. Ideas?
  • nimaaxmed Jan 09, 2009
    My laptop is doing the same thing AND suspiciously enough it's the same Gateway model and everything , i can see the windows still open on
    the screen however it's flashes completely dark. None of the programs close
    i just can barely see them! I think it's simply the internal lamp or something
    but the flashing usually stops after a few minutes :S
Some searching on forums convinced me the inverter had failed. Picked one up for $65, removed the frame around the screen, removed the mounting screw for the inverter, and unplugged both ends of the old and plugged in the new. Put it back togeher and fired it up, bright again. Key here was that a remote monitor still worked which meant video card was OK. The lamp could have been bad, but apparently the life of lamps is pretty decent.
Posted on Feb 02, 2009
What would cause dark blurred display all modes?
I suspect the monitor is dying. Unless it is under warranty, you may need to replace it, as getting it fixed may cost more than a new one.
Jul 25, 2014 | Samsung 22" TFT SYNCMASTER P2250 LCD...
Dark Screen
there is a weird possibility that somehow your PC is configured to save power.. that is something you can do on a laptop to save battery..
you can check in the control panel what is the status of your energy options and see whats going up there..
there is also another possibility that it might be the monitor to be malfunctioning... but if after the screen being dark and you enter the options on the monitor and they are bright i doubt its a malfunctioning monitor..
so try to reinstall the monitor drivers and possibly the drivers of your video card if you have one.. but my biggest bet would be the option energy in the control panel
Dec 22, 2007 | Gateway FPD-1930 19" Flat Panel LCD...
My screen went black while i was working on it and shut down. went 2 power up an no video. any known problems with this model gateway.
Firstly, I would suggest you to try it on another another/External Monitor through Vga port or Hdmi port if available (I can't make it specific since you didn't mention whether your system is Laptop or Desktop). If the video/display shows up on the external monitor, then the problem is with the Lcd of your computer. In most cases, it can be repaired. It'll only need to replaced some parts, maybe capacitors or inverter or backlight led. While the machine is On, look at the display very carefully, and check if you can see the display even if it's dark or not. If you can see the display without light, the problem is with the Backlight, replacing the backlight tube will fix it. But to do this, you'll need to know how to disassemble the monitor/display and how to fit it. All electrician's materials like soldering iron, soldering paste, soldering wire, screwdrivers should be ready. I would suggest you to call and bring a technician or visit a service center.
If the video/display is not showing on the other monitor/external monitor, then the problem is with the system inside the box/case. To start troubleshooting this, first turn off the machine, remove hard disk, Cd/Dvd drive, Ram/s and boot again. Can you see anything on the display, if so, the problem is with one of the removed units, first install the Ram and reboot the system, and then followed by Hard disk and Cd rom. Most problem with no/dark display is related to ram, in rare cases (if unfortunate it with the Bios chip on the motherboard). Sometimes display/video card. If Ram isn't the problem, then your best option replace the motherboard. Some service also repair laptop/desktop motherboard. You can contact Gateway for more details using this form (click here).
If you follow the above instructions correctly, you'll be able to find out the source of the problem.
I wish you good luck.
Thanks for using FixYa.
Aug 09, 2010 | Computers & Internet
The monitor went dark, seems to have no power.
Totally darken the room your computer is in, and see if you can see a very-dim image on your computer.
If so, it could be the "inverter" part inside the LCD that has failed (about a $20 part, but will take a technician about $50 to $75 to disassemble/replace/reassemble/test).
Try connecting the monitor to a different computer, to see if the monitor is OK.
Try connecting a different monitor to your computer, to see if the video-card is OK.
Jun 23, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Hp zt1180 monitor went very dark
Some laptops have a brightness setting in the BIOS, some have a specific button, and some have a configuration program. If you cannot see the screen in a darkened room, your CCFL backlights are not working. Cold Cathode Fluorescent bulbs are tubes along the sides of the display, or top/bottom that light up the screen. If they are not lighting at all, or you can see that only part of the screen is lit, send it back and ask for a replacement or repair. This is assuming it is still under warranty...
If not, prepare to spend some bucks.
tom
Dec 21, 2009 | HP Refurbished PAVILION ZT1180 15 SXGA+...
Unhooked and moved my computer to another part of my room and the monitor now comes on with the power saver display and button is blue, then power saver display goes off and button turns yellos light and...
Sounds as if your monitor is not receiving a signal from your video card. In all likelihood, the video card came unseated during the move. Open the case and re-seat the video card, that should do the trick.
Write back if that does not solve the problem.
-Jon
Sep 29, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
LCD went dark
hook it up to another monitor then control panel then display see i8f something was changed in there
otherwise your screen may have gone but it's only two years old
what were you doing when you lost your screen
Jan 14, 2009 | Gateway MT6707 Notebook PC
Gateway laptop 3522gz display went "dark" after 2 years.
It sounds like LCD backlight problem. Bring your laptop to a repair shop.
Dec 04, 2008 | Gateway 3522GZ Notebook
White corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Gateway 3522GZ Notebook Logo
273 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
