GE Front loader fabric softner wont' drain into tub
  • Anonymous Apr 02, 2009
    fabric softner and bleach dispenser will not dispence.
  • 639 Answers
Peace Friend,
ngfam1 At your service!
Try to find the couple of little wholes in the rear of the softener cup and open them!They are clogged!
If it corrects the problem GREAT!!!
If not only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
The fabric softener is nto being used in the cycle. We put fabric softener in the apprpriate hole and it is still there after the cycle is complete.
The old top loaders would say "use diluted fabric softner" on the dispenser. Yours may not say anything, but this is an easy fix.
Jun 21, 2010 | GE WSXH208A Front Load Washer
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
Fabric softner won't drain
If it is a top loader:
PULL of the fabric softener cup straight up
Rinse out thoroughly
Clean out the holes in the side of the agitator
Nov 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
The machine doesn't drain 100% of the water out. You can move the tub and hear the water sloshing around in the machine bottom and the moisture is now starting to form mold on the front seal
All the water does not drain. The front tub has ballance ring with water sealed in it to off set off ballance loads. The sump hose on the pumpwill also hold water. You can clean your pumps clean out trap to make sure the pump is working good. Also a drain hose higher than 6 ft off floor will cause pump not to drain all water. Front loaders all have a mold problem. no air gets in when your done washing because you close the door. If you dont use bleach and hot water washes it makes matters worse. Fabric softner is even worse.
You need to clean your washer with bleach in the front seal by hand some times.
Its the price you pay for saving water.
Nov 17, 2009 | Kenmore HE2 Plus Front Load Washer
The fabric softner reivore wont take in/ empty the fabric softner
I had this problem also. I pulled the drawer out, then removed the softener assembly. (the blue piece) In the front there is a hole that lets the softener liquid drain into the funnel to go into the machine. It was clogged with a little bit of dried up softener liquid. Cleared that and it worked fine. We've had the washer for 3 years and have had to do this several times. Seems to be a problem.
Oct 08, 2009 | GE WBVH6240F Front Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Fabric softner wont go in the tub from the top dispenser properly
try thinning your fabric softner with a little water,the viscosity of some is higher than others. (this is how thick it is & varys by brand)i think you will find with a little trial & error this will solve the problem.if not,then contact us again & we will try another option.hope this helps & thanx again for using fix-ya .please rate all replys & again thanx.
Nov 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
GE FRONT LOADER WASHER Model#: WBVH5100HWW
You need to put the setting on whites in order for it to take the bleach. Not sure about the fabric softener. I use dryer sheets
Jan 19, 2008 | GE Model: WCVH6260HWW Kitchen Hood
Washing Machines Logo
284 people viewed this question
Top Washing Machines Experts
