Question about Cobra 75 WX ST 40-Channels Handheld CB Radio
Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Bought a Cobra 75 WX ST 40-Channels Handheld CB Radio(used)and now I am looking for a user manual along with the recommadation on what antenna to use. Appreciate any advice or links. Thanks
  • 4 more comments
  • crazycooter Aug 31, 2008
    Greattttt support!!!!!
  • Anonymous Feb 09, 2009
    I shorted out the CB Radio when i accidently touched the red & black wires. Is there a quick fix or do I need to buy a new CB radio?
  • Anonymous Mar 12, 2014
    handheld cb wont work on batteries anymore after using an adapter. It only works with adapter now, what did I damage?
  • Anonymous Mar 18, 2014
    I just have the handheld radio and nothing else where can I get what I need
    Cobra 29 wx nw st cb radio
  • Anonymous Mar 30, 2014
    power output watts
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 31, 2008
  • Greg Cann
    Greg Cann Aug 31, 2008
    Thanks for the good feedback, it makes it all worthwhile!
    Best regards,
    Informatica.
How to pre set channels?
Posted on May 30, 2011
Can't pick up any talk on my cobra 75 ws xt cb radio
Was your antennae set up professionally? You may have a short in the cable or connections or even a bad antennae and/or a bad match. Was it matched with an SWR meter? Have these checked out because it does sound like an antennae or cable/connector issue.
Jan 31, 2014 | Cobra 75 WX ST 40-Channels Handheld CB...
Cobra 75 wx st no sound/speaker does not work. Everything else seems OK according to display
Hi, my name is John. try putting a external speaker in back of radio and see what happens, might need to replace internal speaker, or something internal. Let me know, I will post the process here......Hope this was helpful..
Aug 01, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Cobra 75 WX ST powers on but does not work
MAKE SURE THE ANTENNA IS NOT CONNECTED, THEN TRY AND SEE IF RADIO POWERS UP, IF IT DOES NOT THEN YOU DO NOT HAVE PROPER GROUND
ALSO ARE YOU USING THE COBRA STOCK MIC ?
ALSO MAKE SURE THE RADIO IS ON CB MODE NOT WEATHER MODE
Mar 31, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Change frequency coverage
It would cost about 3 times as much as the radio IF it could be done. I myslef don't believe it can be, techs can't even turn up the wattage in those things.
Jan 15, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Cobra 75 wx st
Hi and welcome to FixYa,
Initially, pls a couple of ideas you may want to consider/explore or try/check:
  • PA/CB switch must be to CB;
  • RF Gain max clockwise;
  • Squelch counter clockwise;
  • Volume to your desired level;
  • Mute (off);
  • external speaker/speaker connection;
  • audio amp, verify if there is TX modulation;
  • antenna, antenna cable. SWR should be low.
Good luck and Thank you for using FixYa. Happy New Year.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate this at all. Cheers.
Jan 01, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Cobra 75 WX ST 40-Channels Handheld CB Radio Logo
944 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
