Question about Fisher Washing Machines
Fisher Paykel Smart Drive 051 washing machine will not start. All other buttons working as normal (can select wash cycle length, temp, water level, etc). Have had no previous problems. When diagnostic mode is selcted (by holding down temp and pressing power on button, the 'rinse' and 'low' (water level) lights come on. What is wrong?
  • 639 Answers
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
How do I get the hot water work for my Fisher & Paykel Eco Smart washer?
How hot is the water temp in the house that you are in? If the inlet hose to the washer is not hot, then it is not the washing machine.
Jul 31, 2014 | Fisher Paykel EcoSmart GWL15
Fisher and paykel smart drive 5.5 won't start a wash cycle, no lights flashing or beeping looks normal but won't start
Contact Fisher and Paykel Service Center and DO NOT TRY TO OPERATE THIS MACHINE UNTIL CHECKED & VERIFIED BY AUTHORIZED FISHER AND PAYKEL SERVICE PROFESSIONAL.
Apr 28, 2014 | Washing Machines
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
My fisher & paykel smart drive 051 will wash then drain, but when it gets to the spin cycle it wont spin at all it fills then drains only.
Possible that the program controller is faulty and is not executing the output when the wash cycle and the drain is done. So the program must advance further to the next stage to drive the motor to spin after the water is pumped off and the water level sensor is reset.
Have the conttroller checked to confirm the fault, look for loose joints in the connections.
If not the controller can be a suspect.
Oct 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fysher and Paykel smart drive 051. takes ages to start. cold water flow seems ok. takes 2-3 times longer for full cycle. sometimes stops and hot water light flashes. yours, jagrat.
Hi just read your posting.Now what water temp have you selected for wash?Is it cold, warm, or hot?Sounds like a water flow problem to me.The water valves on your model of machine sometimes sound like they are filling correctly but they only let a little bit of water in.How long does it take to fill your machine and start agitating when you have selected low water level?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 18, 2010 | Fisher and Paykel Washing Machines
Is there a filter on the smart drive 051- my washing is coming out with dirty black marks
if the black marks come out then it is lint. put 2 pkts bicarb soda into empty bowl, select hot fill, select high water, start cycle. let it wash for 10 min"s , turn machine off, leave overnight. restart cycle in the morning, that should clean tank and bowl. please reply 4 more help.
Apr 23, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
985 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
