Question about Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore hydrawash dishwasher
The dishwasher is 7 years old and today it leaks. It fills ok it washes ok but when it cycles to drain some actually drains and the other half leaks out the bottom by the motor. Any ideas. Thanks
  • 639 Answers
Friend,
ngfam1 At your service!
Drain line from the motor out has a crack or split in it! Sounds simple and an easy repair.
call service below that I gave you!
It sould be a simple repair!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New applinces are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
My GSD5560G03SS GE triton dishwasher has a short wash cycle. Fills, washes for 2 minutes and drains. Sometimes it pauses for 30 minutes after short wash and then drains and dries.
I have a newer model, it usually beeps with an error code when it drains prematurely, due to a leak detected or component problem. If it's under warranty, get it serviced quick, as they will not help you at all once it expires. I gave up and decided to buy another brand after not getting anywhere with them about their poor designed dishwasher that has given me nothing but problems and headaches, and today I discovered a part that was completely inside and encased in plastic that had moisture get into it and rust it right out - my dishwasher has been in use less than 3 years!
Oct 31, 2013 | GE Dishwashers
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Feb 07, 2009 | Kenmore Dishwashers
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Bosch SGS45E08BG/45 Not Washing Correctly
does your dishwasher have a timer or and LCD screen?
if it has timer, replace it or have a techncian do it.
if it has an lcd, replace the touchpad.
Sep 13, 2008 | Dishwashers
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Dishwasher will not drain
I hav an Americana / GE dishwasher, only one and a half years old. the dishwasher is not draining. When I turn the selection knob on the front to wash, is begins filling with water again. But, the cycle is not actually working. I removed the drain hose from the disposal unit and allowed the really really nasty collection of water to drain out. I have a feeling that the hose connection to the washer is clogged. Is this possible. If so, should I remove the hose from the connection at the dishwasher and clean the hose or could it be something else.
Thank you,
Aug 31, 2007 | GE 24 in. GSD4320Z Built-in Dishwasher
Kenmore 24 in. 15079 Built-in Dishwasher Logo
255 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
