Dishwasher did not drain the water properly, the wather remain at the bottom of the machine. I already checked the drain system and looks ok. the machine is a friidaire model FDB641RAB0
  • 639 Answers
Peace Friend,
ngfam1 At your service!
It sounds like a cogged drain line OR a bad pump!
How old is the dishwasher?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
If not only a trained l tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
Then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
Dishwasher (Kleenmaid DW361) not draining properly at the end of the cycle. Just a small amount of water remains in the bottom.
How much is a small amount? I presume this is something new, since a little water always remains to protect the lower seal.
Otherwise, use a flashlight to look into the sink drain and ensure there is strong flow from the DW when it is pumping out water. If not, there may be an obstruction in the discharge line.
On some units (my Samsung??) there is a float chamber on the side (entire unit must be pulled from enclosure) that gets clogged and discombobulates (technical term??) the water level reading, allowing water to remain in the tub. Cleaning required!
Debris may also accumulate under the cover on the bottom of the tub which effects proper draining. Fasteners are usually obvious and you may be surprised at the mess.
Be careful to note positions of all gaskets and screws!
Oct 25, 2016 | Dishwashers
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
My dishwasher model No. is Hotpoint BFI680, There was water lying in the bottom after a wash and it couldn't be restarted, I cleaned it out and took out the drain pump and connected it up to 240volt and...
Hello!
As the manual says:
If water remains inside the
dishwasher, check:
the drain hose is not kinked.
the drain syphon is not
obstructed.
the dishwasher filters are not
clogged.
i also add a link to this manual, hope it will help
Hotpoint BFI 680 User Manual Page 13 of 20
May 23, 2017 | Dishwashers
My Kenmore dishwasher leaves water in the bottom of the dishwasher. Is that OK? I notice the water when I clean out the bottom tray.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 18, 2011 | Kenmore Washing Machines
I have a Zanussi DE6850 free-standing dishwasher. Have just put on a 65 degree programme. After approximately 1 minute the machine has stopped functioning and the top two lights are flashing and water...
You seem to have a blockage,have you checked the filters lately.Also check the drain hose and the pipe that the drain hose goes into,if they are clear then the blockage is down in the bottom of the dishwasher in the pipes or the drain pump.
Hope this helps.
May 21, 2010 | Zanussi 24 in. DE6850 Free-standing...
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher leaving the remains of dish washing liquid all over dishes nothing is getting clean
Is water also standing in the bottom like it isn't getting pumped out? If so, probably the drain system is plugged and everything below the lower spray arm needs to disassembled to the deck--noting the position of each piece as they are removed. Look for food plugging holes in the deck and any obviously damaged parts. Clean the large screen in vinegar and hot water--let soak for a while to remove water and food deposits. Check the drain hose from end to end looking for kinks or other restrictions. Make sure the pump mechanism at the bottom turns freely. Check both spray arms for plugged spray holes or split seams. Reassemble in reverse order. Run a cycle without dishes to clean further--make sure the water drains out at the end. Listen for proper water movement while running. Open the door to inspect progress several times.
Aug 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher did not drain out all of the water
run it again on the hot cycle...if that doesn't work...you have a clogged drain hose or a defective pump.
Apr 04, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
My GE dishwasher after complete washed look like water not out drain (water remain in the tub)
Normally, there is a filter that precedes the pump and that's probably clogged with food by products. Look for the filter screen near the bottom of your dishwasher and remove any debris there.
Another consideration is if your dishwasher drains into/ through your garbage disposal... If so.. make sure that is empty and drains properly when you run the water in the sink. Hope that helps....
Aug 07, 2008 | Dishwashers
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Washing Machines Logo
Top Washing Machines Experts
