Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Hoover Agility The unit blows out air instead of sucking up water.
  • Linda Fountain Oct 02, 2008
    There was a little lint there, but it didn't fix the problem. Thanks!
  • 37 Answers
Check for an obstructed lint filter behind your dirty water tank. if this isn't it please post back.
Posted on Oct 01, 2008
Im trying to blow up an air mattress. Can my hoover agility cyclone blow it up or dose it only suck things up??
Unfortunately you've got suction only on that. Your best bet would be to find an old Electrolux canister vac to hang on to, thosee always had a way to plug the hose into the exhaust for blowing.
Nov 16, 2014 | Vacuums
Why is my hoover agility not sucking up water
It is likely the recovery tank lid is loose. This means the suction is loosing. Worst case is the suction pump is faulty.
Look at this manual in the troubleshooting section.
http://hoover.com/file/655/
Sep 03, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
Blows air out, not sucking in. Hoover Agility F215-900
It's most likely it's not blowing air out, rather the brush is kicking debris back and out due to loss of suction..
Another possibility with the power head is a cracked or leaky tube between the tank and power head.
For the tank, check all areas for clogs, and clear them.
Dec 19, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
The hoover agility that I borrowed is not sucking up water, I don't have a manual, can anyone help. I probably put it together wrong.
You will find this URL of help:
http://www.ereplacementparts.com/search_result.php
Please provide a Thumbs Up if you find this solution helpful.
Paul
Oct 10, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Agility steam cleaner
Sounds like you have a broken water line, or it just came off. You would have to remove the top housing to get to the water lines. Or at the bottom of where the solution tank sits on, is the reservior asm. there are lines going there also. Bottom of the tank, the valve is stuck open. The trigger on the handle is stuck pushing down on the reservior asm.
Jan 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
SteamVac Supreme Vacuum Problem:
Does this have the slot in front of the dirty water tank for the hose? If it does and the hose isn't installed, there is a block that you put in when the hose isn't being used. If not there, then it will blow air and won't suck up.
Nov 11, 2007 | Hoover F5832-910 SteamVac Supreme Vacuum
Suction
Opening that door and attaching the hose will let the suction go thru that hose. So if when you removed the hose, if that door isn't closed tight will cause you to have a suction problem It has to seal and have no leaks. The other thing when be a problem with the recovery tank not sealing when you put it back on. Other then that, any air leak will cause a suction problem.
Apr 19, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
235 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
