Question about Acer Computers & Internet
Resetting the CMOS
I've got an acer aspire 3100 and I need to reset the CMOS but can't find it. Any ideas?
  • 781 Answers
On boot up press one of these keys
F1, F2, CTRL +ESC, DEL or on the bottom of screen will be word saying to enter BIOS press?? key
one of these should do the job
Posted on Aug 31, 2008
Aspire x1800
Setting up a password on the Acer Aspire prevents others from accessing the computer without permission.
If the user is unable to supply the correct password at startup, the computer will lock the hardware and fail to boot.
This security measure is a useful feature, but it can create serious problems if you forget the password.
Basics
The Acer Aspire stores the password in a component called the complementary metal-oxide semiconductor.
This component is integrated into a random access memory chip embedded on the motherboard. The CMOS holds data that the basic input/output systema critical software utility that controls how the computer operates at startupaccesses when the computer boots.
If the BIOS detects that a password is registered in the CMOS, it will prevent the computer from booting until the user enters the password correctly.
Depending on which model of Acer Aspire you own, you may be able to clear the CMOS manually.
Contact Acer before attempting to clear the CMOS, as opening the computer without permission could void your warranty.
Desktop Models
Some Acer Aspire desktop models come with a jumper that is used to clear the password and other settings stored on the CMOS.
This jumper is located on the motherboard and is often found next to a label such as "JBIOS1" or "CLR_CMOS." To clear the CMOS using the jumpers, turn off the computer, disconnect the power cable and remove the case cover.
Remove the jumper shunt from pin 1 and pin 2; then place the shunt on pin 2 and pin 3. Return the shunt to its initial position after 10 to 15 seconds.
If the Aspire doesn't come with a jumper to reset the CMOS, the CMOS can be reset by removing the lithium coin-cell battery instead.
Removal is accomplished by pushing down on the tab securing the battery to the motherboard and lifting the battery out of its slot.
Leave the battery out for 24 hours, and then return it to its original position with the positive sign facing up.
Laptop Models
Resetting the CMOS password on an Acer Aspire laptop is much more difficult than resetting the password on a desktop.
Disassembly steps vary from model to model, but on most models, you'll have to take apart the computer to access the CMOS battery.
Don't take apart the notebook if you don't have experience disassembling PCs.
After turning off the computer and disconnecting the AC adapter, take out the battery (different from the CMOS battery).
All visible screws must then be removed from the bottom of the notebook.
Remove all components stored to their separate compartments on the base of the notebook.
Turn over and open the PC.
Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible.
Remove the keyboard.
Remove the screws securing the monitor to the hinges, and then set the monitor aside. Disconnect all visible cables connected to the motherboard; and then remove the screws from the top cover.
Remove the top cover to reveal the motherboard.
Locate and then remove the CMOS battery.
Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire.
Other Options
If removing the CMOS battery fails to clear the password, or if you don't feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password.
These special passwords were implemented to allow technicians to access locked computers. Not all models recognize backdoor passwords.
Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include "BIOS," "CMOS," "phoenix" and "PHOENIX."
All of these passwords are case-sensitive.
May 04, 2014 | Acer Aspire Computers & Internet
Reset bios
Resetting the BIOS is hardware related you have remove the CMOS cell for atleast 30 mins. You need to remove the keyboard and its panel the CMOS cell is located rite underneath the keyboard.
Sep 19, 2013 | Acer Aspire 5610-4648 Notebook
Computer was locked
Turn over and open the PC. Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible.
Remove the top cover to reveal the motherboard. Locate and then remove the CMOS battery. Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire.
Other Options
If removing the CMOS battery fails to clear the password, or if you dont feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password.
Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include BIOS, CMOS, phoenix and PHOENIX.
Apr 22, 2013 | Acer Computers & Internet
How to unlock a computer
Is it an aspire ?
Other Options
How to remove the bios password and the windows password
Step 1:
The Acer Aspire stores the password in a component called the complementary metal-oxide semiconductor. This component is integrated into a random access memory chip embedded on the motherboard. The CMOS holds data that the basic input/output system - a critical software utility that controls how the computer operates at startup - accesses when the computer boots. If the BIOS detects that a password is registered in the CMOS, it will prevent the computer from booting until the user enters the password correctly. Depending on which model of Acer Aspire you own, you may be able to clear the CMOS manually. Contact Acer before attempting to clear the CMOS, as opening the computer without permission could void your warranty. Desktop Models Some Acer Aspire desktop models come with a jumper that is used to clear the password and other settings stored on the CMOS. This jumper is located on the motherboard and is often found next to a label such as "JBIOS1" or "CLR_CMOS." To clear the CMOS using the jumpers, turn off the computer, disconnect the power cable and remove the case cover. Remove the jumper shunt from pin 1 and pin 2; then place the shunt on pin 2 and pin 3. Return the shunt to its initial position after 10 to 15 seconds. If the Aspire doesn't come with a jumper to reset the CMOS, the CMOS can be reset by removing the lithium coin-cell battery instead. Removal is accomplished by pushing down on the tab securing the battery to the motherboard and lifting the battery out of its slot. Leave the battery out for 24 hours, and then return it to its original position with the positive sign facing up. Laptop Models b> Resetting the CMOS password on an Acer Aspire laptop is much more difficult than resetting the password on a desktop. Disassembly steps vary from model to model, but on most models, you'll have to take apart the computer to access the CMOS battery. Don't take apart the notebook if you don't have experience disassembling PCs. After turning off the computer and disconnecting the AC adapter, take out the battery (different from the CMOS battery). All visible screws must then be removed from the bottom of the notebook. Remove all components stored to their separate compartments on the base of the notebook. Turn over and open the PC. Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible. Remove the keyboard. Remove the screws securing the monitor to the hinges, and then set the monitor aside. Disconnect all visible cables connected to the motherboard; and then remove the screws from the top cover. Remove the top cover to reveal the motherboard. Locate and then remove the CMOS battery. Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire. Other Options b> If removing the CMOS battery fails to clear the password, or if you don't feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password. These special passwords were implemented to allow technicians to access locked computers. Not all models recognize backdoor passwords. Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include "BIOS," "CMOS," "phoenix" and "PHOENIX." All of these passwords are case-sensitive.
Mar 26, 2013 | Acer Aspire One AOD257-1497 Atom N570...
Acer Aspire 9300-3716 password
My advice to you is technical. You need to reset the CMOS on the motherboard internally. As for the password in vista unless you know it you will more than likely have to re-install vista or do a systme recovery by using the e-recovery partition that comes stock with ACER computers. I do not advise you to try resetting the cmos if your not technically capable
Dec 01, 2009 | Acer Aspire 9300 Notebook
How do I reset the setup password for my acer aspire 4520
Try resetting the CMOS switch on your motherboard.
If you need help finding it, please post your motherboard model here.
Jun 11, 2009 | Acer Aspire 4520-5582 Notebook
ACER ASPIRE 3100
You will need a restore cd for the acer.
If you have lost the cds that came with it, you can buy new ones from this page http://www.recovery-cds.com/laptop/product.asp?product=1247&ph=search&keywords=acer,3100&recor=1&SearchFor=any&PT_ID=all
Nov 23, 2008 | Acer Aspire 3100-1405 (AS31001405) PC...
Acer aspire 3100 series
If you where the CMOS battery is, there's beside it a jumper inserted in two of the 3 pins(left pin and middle pin). Remove the jumper from its original position and with it short the middle pin and right pin. This resets the CMOS ROM to its default settings minus the password. Return the jumper to its original position as before. Reboot the computer.
Apr 25, 2008 | Acer Aspire 3100-1405 Notebook
My Acer Aspire 5100 clock keeps falling behind...
if the clock is consistently being resetted then most likely you have a failing cmos battery. you need to dismantle the laptop in order to have access to the cmos battery. you need to fina a COIN type battery.
Apr 12, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
323 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
