Question about Microsoft Windows XP Home Edition
Blank monitor screen
When I start up my laptop it's just a blank screen. What have I done and what do I need to do?????
  • 1 more comment
  • faith_22 Aug 31, 2008
    Yes, it's as soon as I press the power button there's nothing but a blank screen. There is no blip on the screen to a logo or anything. I can hear the laptop starting up but the thing is that it's as though the screen somehow been disabled, i don't know.
  • ciufo Dec 09, 2008
    I have the same problem. I just recently tried to update the bios and it froze so I tired to reboot and all I got was a blank screen. The screen works fine what would be the problem?
    Sergeant:
  • 336 Answers
First, IS THE SCREEN ON? You would be surprised but 92% of peoples problems are as simple as turning on the power. Second if it is on do you see anything, anything from a blip on the screen to a logo? I will be able to assist you further once I have this information.
RCF
Posted on Aug 31, 2008
  • Ryan Frame
    Ryan Frame Aug 31, 2008
    Next step. If you know a friend who has a computer try to attach your monitor to his/her computer and see if it works then. If it dosen't work Change the Cable with another cable, sometimes the cable breaks. If that still dosen't work, Your monitor has overheated and a part has burned out. I would then recommend buying a new screen. But if your are reasonably sure that the screen is not broken just ask me to continue troubleshooting.
    RCF
I have a dell studio 1558 laptop, suddenly while using the laptop the screen for blank so i did a hard shutdown. After that i tried starting my laptop, but there was only blank screen. I attached my...
Seems like a two fold issue here. The blank screen is possibly a faulty laptop display or inverter but the blue screen is caused by powering off the laptop whilst it was doing something and now has damaged files. With your external monitor connected power up and try to reach Safe Mode and let windows find the issue and attempt a repair or press F8 and select repair OS. When you have repaired the OS, shine a bright light at the laptop screen and see if the inverter is not running or a dead screen.
Oct 28, 2014 | Computers & Internet
Screen is blank when i turn my compter on
While it is on, look very closely at the screen. If you can see the login screen but it is extremely faint. Then you have a bad inverter board. This piece is located typically in all the base of the display. Moderate to difficult to replace. If you have a monitor with a VGA, DVI or HDMI depending on what your laptop supports connect the monitor to the laptop and try toggling the display. Usually done with the function (fn) key and one of the F# keys. If you get a display then it is probably the screen itself that is bad. If you get nothing then probably the motherboard.
Apr 17, 2012 | Dell Inspiron 1750 Laptop
Screen is blank how do I get it to work again
Do you need the external monitor to switch it back to internal monitor or both on?
Feb 07, 2012 | Lenovo 3000 G530 PC Notebook
Got an acer aspire ax3812 tower is on but screen stays blank got any ideas
Change the internal Ram sticks. This can cause a "Hold" in the BIOS boot process, thereby stopping the machine from going to the Operating System. Hope this helps.
Jan 29, 2012 | Acer Aspire Computers & Internet
Eee Pc starts with blank screen. it starts up and goes straight to a blank screen. wireless and power light on. No hard drive light. what can be done to this?
it could be a ram issue. if you're proficient with your hardware and the lappie is out of warranty try removing the ram sticks then re-seating them. this resets the ram and allows the monitor to turn on
Feb 25, 2010 | ASUS Eee PC 1000H Laptop
Acer aspire 5310 the screen just blank and not
Possibly the monitor is defective - usually most laptops have a blue plug at the back for an external monitor, if plugging in a normal monitor brings up a screen, then likely the laptop monitor is defective. If you get a splash screen and bios info on trying to start it,it indicates your windows is defective or has lost it's start-up files - a windows reinstall will fix that.
Aug 29, 2009 | Acer Aspire 5315 Notebook
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
HP DV2000 screen going blank when try to restart my laptop
Check the swapping monitor function screen FN + F4 on Compaq.
It allows to change from internal to external or Both monitors.OR
Start in Safe mode with VGA basic settings and configure your Display settings.
Dec 14, 2008 | HP Pavilion dv6000z Notebook
Compaq monitor blank screen
If its a blank screen all the time that never shows anything not even a screen at startup then it sounds like the internal cable from your monitor to the motherboard of the laptop is unplugged or possibly broken. You need to remove the keyboard from the laptop to check this.
I recommend bringing the laptop to a professional if you have no experience with opening laptops.
Oct 17, 2008 | HP Compaq Presario 1700T Notebook
Blank screen
your pc no good call your comper sellwer
Apr 01, 2008 | HP Compaq nc4010 Notebook
Microsoft Windows XP Home Edition Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
