Question about Samsung Digimax V4 Digital Camera
Samsung Digimax V4 Power Consumption
I bought this camera a while ago, everything on this camera works fine but I think I have some problems with power supply.. I use 2100mAh GP batteries. I have a feeling that it consumes power too fast - I did a test.. I turned off the Power off mode and then waited till it turned off by itself because of a low battery power.. It lasted 45 minutes to do so. I think that batteries should last longer? or I'm wrong? i also noticed that when I was taking pictures in a medium resolution mode i took about 120 pictures using flash.. but when i turned it into a high resolution mode i could only took about 40 pictures with flash is that normal or is something wrong with my camera?
    Master:
  • 542 Answers
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Posted on Sep 12, 2005
Wacker gp 5600 will not power anything above 3400 watts, any ideas on what may be causing this issue. we have checked everything (wires, fuses,gfci)unit still will trip circuit breaker at 3400 watts.
5600 is the maximum wattage it can handle during a power surge, the this is not the load it can carry all the time. I think you have no problem here.
Jul 03, 2017 | Electrical Supplies
PLEASE HELP! -- I have now bought 2 Sony DCR-TRV350's. One, I bought originally in 2003 and has worked like a charm up until a few months ago. I have a bunch of old tapes that I never got around to...
Found this post re: Sony C:31 errors
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/Sony_DCR-TRV18_-_Error_Code.
In a nutshell: - Remove tape and close door - Remove all power supplies (battery and AC) - Smack the bottom of the camera hard with your palm - Reattach power supply, insert tape and try again
This solution has worked for me, but problem usually reappears after a few uses.
Dec 09, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
I have a Casio Exilim camera which was working fine. I went to use it a few days ago and there was no power. The battery appeared to not accept a charge so I figured it was past its sell by. I bought a new...
Casio cameras use generally chinese batteries. They are mostly under an acceptable quality. So the battery you have bought may be out of order. I do not think that your camera is out of order.
Try another working battery.
If it will not work then send me a comment and lets control additionally.
Jun 03, 2010 | Casio Exilim EXZ75 Digital Camera
Ionic Breeze GP S1830
Hello, My name is Joseph Veres and I from NJ. I bought it the
Ionic Breeze GP S1830 about 4 year ago. I had been a problem and I can feeling a burried . Can replacement this? Please, let know e-mail me asap. my e-mail is jveres53@yahoo.comThank you
Joseph Veres
Jul 14, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Hi. I have a Canon G9 camera. I bought in October 8, 2007 but did not register the camera's warranty until a few days ago. Here's the problem. I dropped the camera a weeks ago... Everything was...
Hi Cacy,
I don't want to offend you, please don't take it that way, but since your problems began with the addition of the new battery... I have to ask the question. Are you absolutely sure you bought the right battery for your camera?
It takes a NB-2LH battery pack. If your sure you purchased the correct battery for the camera, and since you dropped it, I would check to make sure it seats properly in the camara and that it locks properly. Also the cover should close with a CLICK sound. If it doesn't then perhaps the battery is not locking in properly. Double check it and let me know if you still have problems.
Rob
Mar 09, 2009 | Cameras
AGP x1650 pro 256mb just stops working
you wont damage anything but get at least a 450-500w power supply. Nothing should be damaged
hope this helps
Jan 03, 2009 | Power Color 256MB PowerColor ATI RADEON...
Cannot power on to take photos
I found that one has to use their batteries of at least 2100mAh and NI-MH. I recharged my batteries removed the new ordinary alkaline batteries I had put in and BINGO IT WORKED. Just to prove the point I put in another set of Alkaline batteries No good. It must be that NI-MH Batteries rated at 2100mAH have more power (or one can draw more currentat start up) a battery guru could maybe veryify my conclusions. Anyhow try NI-MH batteries and see how you go. Best of luck fredlich
Aug 15, 2008 | Sony Cyber-Shot DSC-P93 Digital Camera
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Camera won't turn ON
First off, everything was not fine until this morning. You had this occur a month ago. Frankly, I would have done exactly as you did a month ago and nothing more. I have seen too many electrical problems permanently solved by turning a device off and then on, or by rebooting. Here is what I would generally recommend: 1. See what the camera manual suggests. 2. Charge the batteries fully before using them. New ones are often not charged up. They could have been in a warehouse for months. 3. The electrical contacts on your camera, the ones that interface with the batteries, may be a little corroded. If you can access them easily, try cleaning them with the eraser on the end of a pencil. Same with the batteries themselves. 4. If exposed to prolonged high humidity, electrical problems may include not only the power supply, but other electrical switches, such as the reset button., which you cannot address on your own. 5. Call Sony.
Sep 13, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
AC/DC power supply
YOU CAN USE ANY AC ADAPTER THATS 3VOLTS 1500mAh OR 1.5A WHICH MEANS THE SAME THING IF YOU GO TO YOUR LOCAL ELECTRONIS STORE AND TELL THEM THIS THEY SHOULD BE ABLE TO DIRECT YOU TO THE RIGHT ONE
Sep 04, 2005 | Fuji FinePix A303 Digital Camera
Samsung Digimax V4 Digital Camera Logo
129 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
