Question about Timex Watches
Can't get the back of my timex watch to replace the battery
  • 2,071 Answers
I have sample video guide of how to open ,tell me whatever the result ,so i can assist...
How to replace a watch battery - Watch
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Sep 07, 2008
Back has NO screws. How do I easily remove it to replace the two batteries?
Hi, You may know that this watch runs on two batteries, one for digital display and another for analog hands.
If the analog hands stop working all you need to do is to replace the battery and please replace both at the same time since the band and cover take some effort to remove.
You need to take off the both bands first to access the back side than the back cover with a small knife..
Just in case,if you need the user manual here is the link.
Timex watch: http://www.timex.com/info/Product_Instruction_Guides_Downloads .
Take care..
Regards
Jun 14, 2011 | Timex T56381 42 Lap Ironman Triathlon...
Replace battery on 15 yr old timex alarm/chronograph?
You have been very Non Specific about which of many Timex watch you own.
So to send you in the right direction the back should pop off and one of the more popular batteries in the day was the SA357
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 20, 2010 | Timex Watches
My watch back 5 minutes in an hour
The first thing to do is to replace the battery. If after battery replacement your watch still loosing time - there is a technical/mechanical or micro-electrical problem and you will have to look for professional watchmakers help.
Rate me, plz.
Jan 08, 2010 | Timex Watches
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Timex expedition compass battery replacement?
hi
i am not an expert in this particular case but i followed theses below steps . here are they.....
Unscrew the case back with a case back tool (aka Jaxa wrench) which engages
the notches in the case back. I'm assuming the watch has a screw back - if
it has notches it does. Pop out the old battery.
In some watches you have to
unscrew a clip but in most the battery pops right out. Examine movement for
evidence of battery leakage or other damage. Carefully clear away any crud
at the edge of the case - the tiniest metal shaving will short out the coil.
Install new battery of same type. Handle new battery with non-metal tweezers
or rubber gloves, never bare fingers. Inspect case back gasket or preferably
just replace it with new o-ring of same size. Gasket should be lubricated
with silicone grease. Reinstall case back using wrench. If you are
concerned with water resistance the watch needs to be tested in a pressure
test machine. I'm sure the pros have more tips but this should suffice for a
Timex where it would not be a big loss to damage or break the watch.
i hope you can successfully replace the battery
thank you
Sep 06, 2008 | Timex Digital Expedition watch
Have timex watch had battery replaced and watch quit working, she had to use clamp device to instal battery
If you had the battery replaced, I'm guessing that the watch wasn't working when you brought it in for a new battery. It may not have needed a new battery. You might need a new watch. I've never heard of anyone needing a clamp for a Timex digital watch. In my experience, they use phillips screws to hold the back to the case. I have a case press for snap-on backs, but that's still unusual for a Timex unless it has a BIG case. I think your watch was shot before you replaced the battery.
Apr 26, 2008 | Casio Atomic-Solar Watch GW300
Watches Logo
314 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
