Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
60pp9202/17f no picture after IC instal
I just installed the IC's and now i dont have any pictures any suggestions on where to start?
  • Philips Master
  • 8,617 Answers
Double check the IC pins to be sure they are all soldered without any bridging and then doublecheck your wire connections
Posted on Aug 31, 2008
Mitusbushi VS-4544 Horizontal lines then looses picture.
I'll take a guess here that the lines are at a slight angle. I believe that these are "retrace" lines and are an indication that the flyback transformer is starting to fail. The vertical IC would cause a collapse of the picture and bad caps in the circuit would effect the linearity of the picture. You can check for poor solder joints as they could cause any nunber of symptoms.
Keep us posted.
Dan
Jul 14, 2008 | Mitsubishi VS-4544 45" TV
Problems after new ic chip install
Did you check for open resistors in the convergence circuits? Often that is what happens when the old ICs wear out it will cause a couple resistors to burn open, and they show no outward sign of being bad. Also double check the IC pins connections for solder bridges thats another common problem, I always use a magnifying glass to double check my solder when ever I do convergence or any IC work where the pins are close. But with the streaks youre describing I would think maybe resistors.
Jun 16, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
"Operation Failed" on start up
change the battery and clean the tips, where the battery connects and try2 reset u\r phone its secorty code ic 00000.reply me
Jun 03, 2008 | Motorola Mobility RAZR V3
Red and green distortion
The convergence Ic needs to be replaced. I am not sure which STK number is used in that model as I dont have Info on the VZ6 chassis. But you can get a replacemeny IC with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Jun 01, 2008 | Televison & Video
Strange Picture Issue
Your convergence ICs are getting weak and will need replacing soon. You can get replacement ICs with free installation instructions and free online tech support during the repair which takes about an hour. If you dont know what IC numbers you have in your set . hit the contact link on the lower left section of the front page and give them your model numver and they will email you back with your correct IC numbers.
Apr 07, 2008 | RCA P46921 46" Rear Projection Television
Old tv's
I dont think you need a picture tube. If the audio still works when the picture goes out I would suggest checking the solder on the vertical output IC that could make the picture tubes blank out. Look for hairline cracks and resolder just to make sure. Let me know how you make out or if you need more info.
Mar 13, 2008 | Zenith R57W46 57" Rear Projection...
53swx10b bowed picture
Double check your work for errors such as solder bridges or incorrect resistor placement. Look carefully anywhere solder could have dripped or splattered to cause the bowing. If you entered the digital convergence mode to touch it up, you will have to re initialize the magic focus for it to function. Good luck
Mar 12, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Philips 55PP9401 no sound no picture
When Replacing the (STK'S Power Pak) for this set you must use OEM parts. After market I.C. will not work!!! They will give you problems like you are discribing. D,TV
Dec 14, 2006 | Philips 55PP9401 55" Rear Projection...
Toshiba model 61HX70 convergence issue
It is a good possibility you damaged something on that PCB that had the IC's, I like to use an upgraded chip the STK394-160e that is designed for HD signal stresses. I dont know why they ordered the convergence board but I suspect it would have been ok, there are also 2 jumpers that need soldering JW10 and JW50 that supply power to the chips and they REQUIRE resoldering or it will fail again. Might try reseating the RED CRT board, check for cables that you may have unhooked to see if they are not seated in their sockets properly, double check every wire you unhooked, Make sure you used a Silicone Heatsink Compound on to the back of the IC's. I dont know what all you unhooked, but check the wires going between the CRT Boards. Check for cracks in the boards to make sure they werent flexed to much. Good Luck.
Sep 09, 2006 | Toshiba 61HX70 61" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
