Question about ASUS Computers & Internet
Bios hi there, i hav e an error message on boot up which says the my hardware isn't istalled . bios not found (or words to that effect) how can i fix this?
    Brigadier General:
  • 5,158 Answers
Reflash the bios for your motherboard .... make sure you have the correct one.
Posted on Aug 31, 2008
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
Bootmgr missing
You are not alone in this problem. There are people who are experiencing the same problem. If the problem isn't hardware related (which usually isn't), then you can fix this problem if you have the windows DVD handy (I'm referring to the operating system reinstallation disc).
Insert your OS DVD to boot to the disc.
Just follow the onscreen instructions and click next. After that, you can find a link in the lower left hand side that says "Repair Your Computer"
Just click on it and the computer or OS will try to find the fix to the problem by checking the disc. The computer will automatically overwrite the missing bootmgr and it should fix the problem.
If you have any problems right after doing this fix, please let me know.
By the way, I suggest that you isntall RadarSync to your computer so that you won't have any problems with your computer's driver. Hardware drivers are very important and they are sometimes what causes problems in your computer.
Hope this helps,
Carlo Adrian Canon
Nov 16, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
Grub loading stage 1.5.,Grub loading please wait,Then it say Error-18
Because Grub has to fit in a small space on the disk, there is no room for helpful error messages, but 'Error 18' translates as 'Selected cylinder exceeds maximum supported by BIOS'. In other words, your BIOS - which initializes hardware - is unable to handle a hard drive this large. Windows is able to boot because the Windows partition is at the start of the distro's disk, within the area handled by the BIOS. This is not a limitation of Linux, which hasn't even started to load, but your hardware. You would see the same problem if you tried to install two versions of Windows, say 98 and XP. There are a few ways to deal with this.
Mar 05, 2012 | Compaq Armada M700 Notebook
When switcthing on my Advent netbook it comes up with the error message Windows Boot Manager Windows Falied to Start. A recent hardware or software change might be the cause. To fix the problem: 1....
Hi sioban_bros,
Based on your situation. I suggest trying the following steps:
1. restart the computer and keep pressing F8; Use Last Known Good Configuration.
2.If the issue still occurs after that, I suggest testing if we can boot from a Windows XP disk. If so, please install Windows XP on another partition and access your important data.
3. After backing up those data, you can use Windows XP disk to format the drive and reinstall your preferred operating system.
4. However, if we cannot boot from a Windows XP disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
To access the data on the drive, you can try to install the hard drive on another computer.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Advent Netbook
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
Tell me aboout boot sequence in bios setup
The system BIOS is what starts the computer running when you turn it on. The following are the steps that a typical boot sequence involves. Of course this will vary by the manufacturer of your hardware, BIOS, etc., and especially by what peripherals you have in the PC. Here is what generally happens when you turn on your system power:
The internal power supply turns on and initializes. The power supply takes some time until it can generate reliable power for the rest of the computer, and having it turn on prematurely could potentially lead to damage. Therefore, the chipset will generate a reset signal to the processor (the same as if you held the reset button down for a while on your case) until it receives the Power Good signal from the power supply.
When the reset button is released, the processor will be ready to start executing. When the processor first starts up, it is suffering from amnesia; there is nothing at all in the memory to execute. Of course processor makers know this will happen, so they pre-program the processor to always look at the same place in the system BIOS ROM for the start of the BIOS boot program. This is normally location FFFF0h, right at the end of the system memory. They put it there so that the size of the ROM can be changed without creating compatibility problems. Since there are only 16 bytes left from there to the end of conventional memory, this location just contains a "jump" instruction telling the processor where to go to find the real BIOS startup program.
The BIOS performs the power-on self test (POST). If there are any fatal errors, the boot process stops. POST beep codes can be found in this area of the Troubleshooting Expert.
The BIOS looks for the video card. In particular, it looks for the video card's built in BIOS program and runs it. This BIOS is normally found at location C000h in memory. The system BIOS executes the video card BIOS, which initializes the video card. Most modern cards will display information on the screen about the video card. (This is why on a modern PC you usually see something on the screen about the video card before you see the messages from the system BIOS itself).
The BIOS then looks for other devices' ROMs to see if any of them have BIOSes. Normally, the IDE/ATA hard disk BIOS will be found at C8000h and executed. If any other device BIOSes are found, they are executed as well.
The BIOS displays its startup screen.
The BIOS does more tests on the system, including the memory count-up test which you see on the screen. The BIOS will generally display a text error message on the screen if it encounters an error at this point; these error messages and their explanations can be found in this part of the Troubleshooting Expert.
The BIOS performs a "system inventory" of sorts, doing more tests to determine what sort of hardware is in the system. Modern BIOSes have many automatic settings and will determine memory timing (for example) based on what kind of memory it finds. Many BIOSes can also dynamically set hard drive parameters and access modes, and will determine these at roughly this time. Some will display a message on the screen for each drive they detect and configure this way. The BIOS will also now search for and label logical devices (COM and LPT ports).
If the BIOS supports the Plug and Play standard, it will detect and configure Plug and Play devices at this time and display a message on the screen for each one it finds. See here for more details on how PnP detects devices and assigns resources.
The BIOS will display a summary screen about your system's configuration. Checking this page of data can be helpful in diagnosing setup problems, although it can be hard to see because sometimes it flashes on the screen very quickly before scrolling off the top.
The BIOS begins the search for a drive to boot from. Most modern BIOSes contain a setting that controls if the system should first try to boot from the floppy disk (A:) or first try the hard disk (C:). Some BIOSes will even let you boot from your CD-ROM drive or other devices, depending on the boot sequence BIOS setting.
Having identified its target boot drive, the BIOS looks for boot information to start the operating system boot process. If it is searching a hard disk, it looks for a master boot record at cylinder 0, head 0, sector 1 (the first sector on the disk); if it is searching a floppy disk, it looks at the same address on the floppy disk for a volume boot sector.
If it finds what it is looking for, the BIOS starts the process of booting the operating system, using the information in the boot sector. At this point, the code in the boot sector takes over from the BIOS. The DOS boot process is described in detail here. If the first device that the system tries (floppy, hard disk, etc.) is not found, the BIOS will then try the next device in the boot sequence, and continue until it finds a bootable device.
If no boot device at all can be found, the system will normally display an error message and then freeze up the system. What the error message is depends entirely on the BIOS, and can be anything from the rather clear "No boot device available" to the very cryptic "NO ROM BASIC - SYSTEM HALTED". This will also happen if you have a bootable hard disk partition but forget to set it active.
Dec 15, 2010 | HP Computers & Internet
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
Can't boot up
reformat it using Windows XP SP2
Feb 15, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
