Question about Olympus Camedia C-750 Ultra Zoom Digital Camera
Flash vs No Flash
I noticed not using the flash could make a picture much blurrier than a picture with flash. I'm just curious why the flash would make that much of a difference for quality (instead of just making it darker)
    Master:
  • 852 Answers
Probably what's happening is that the shutter speed is automatically adjusted to a faster speed with flash. With no flash the shutter speed slows down to compensate for the lack of light, therefore leaving it open longer. So while you are holding the camera during a longer exposure you are promoting camera shake, thus blurry pictures. The LED may tell you information you need to know like shutter speed, apture, flash on/off, etc.
Posted on Sep 12, 2005
I have the Canon Rebel EOS T2i and often get a "busy" message that locks up my camera and I miss several shots
Jlaurice,
This can be caused by number of variables - RAW vs JPEG, the size/quality, if you are using flash, level of battery and the type of SD card you are using, live view, etc. I highly recommend making sure that you have a quality SD card that is rated with a class 10 (10MB/s) transfer rate or higher.
Do you notice a difference if you are using flash or not? I've seen this before where using the flash will results in a situation like you have described, but cannot be replicated with no flash in good light.
That said, if you are using AF assist on the camera, it will measure the distance to your subject and determine the "amount" of flash needed, so if you are shooting at a longer distance, this can increase your recharge time.
I hope this helps.
Thanks.
Feb 27, 2011 | Canon EOS Rebel XSi Digital Camera
8mb vs 8gb of space on an 8gb flash drive
sounds like you upgraded it to a dynamic volume and are using the leftover space, flash drives should be left as basic disks and formatted fat 32.
Mar 15, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Camera fails to flash every time we take a picture
1.Turn off the camera.
2.Install a set of new or fully charged batteries into the camera. then turn it ON
3.Press the Flash Status button to scroll through the flash options until Fill Flash (the lightning bolt icon alone, with no other letter or symbol) is displayed. This forces the camera to use the flash. a86196b.jpg
4.Take a picture. [If flash still doesn't work contact Kodak support line 1 800 235 6325 (23KODAK)]
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
Blurry indoor results- using flash
Built in flash units on digital cameras are only meant to be used out to a distance of 6-12 feet. When taking photos of events ie graduations, sporting events, concerts you need to do two things. 1). Change the ISO setting on your camera. This is the same as the old film speed ratings the higher the number the more sensitive the camera becomes. try ISO 1600 or above in low light. 2) You have a mode setting, set it for the type of lighting that is in the space you are in, incandescent, flourescent or whatever, it's easy to do. and finally 3) Turn off your flash! When your flash is on your camera closes up the aperature and takes the picture at a higher rate of speed in anticipation of reflected light off of nearby objects, so your pictures will be darker and blurrier with the flash on.
Even high grade professional flashes only work out to 20-30 feet so they won't help you. Read your cameras manual on taking pictures in low light conditions. It will give you all of the above in great detail. You have a great camera but you need to learn how it works, don't give up on it.
Jun 02, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Canon sd900
Try a higher ISO speed (suggest 400). Look in your camera's instruction book to find out how to do this.
May 27, 2008 | Cameras
Flash
you may need to try using a different flash, if you click the flash button various times you may notice that there is different flash options.
Nov 24, 2007 | Praktica SlimPix Digital Camera
Pictures are dark, even when flash is being used
Press the FN button under the toggle on right side of LCD screen. You will see white balance on left. Toggle down to the "flash" symbol".  Should work a treat now. If not using flash go to FN again and raise ISO.(Don"t forget to go to Auto white balance again!!)
Sep 17, 2007 | Pentax *ist DL Digital Camera
Flash doesn't work as it should
Hello, in order to repair your camera the IC851 is to be replaced. This integrated circuit is used for flash control. Please do not try to fix it yourself. Contact your nearest Authorized Sony Service. If you need more info please advice.
Aug 24, 2006 | Sony Cyber-Shot DSC-W5 Digital Camera
Battery problem
I find that the Nikon 4300 really burns through the batteries when the camera is set to use red-eye correction. This triggers three or so flashes for each picture. I think I get more than 30 red-eye corrected flash pictures on a set of batteries, but probably no more than 50. Taking outdoor shots w/o flash naturally is kinder on the batteries.
Sep 14, 2005 | Nikon Coolpix 4300 Digital Camera
Olympus Camedia C-750 Ultra Zoom Digital Camera Logo
49 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
