Question about Frigidaire Dishwashers
What wire size is needed to run power line to an 18" frigidaire dish washer
  • 706 Answers
The first thing you'll need to find out is how much current the dishawasher uses.. for example .. if it is less than 15amp ( which most are) then 14 awg wire is appropriate.. If it is more than 15 amps and less than 20, 12 awg wire is required.. You need to make sure that the circuit breaker feeding this appliance is sized correctly for this.. In some states.. dishwashers and garbage disposals are wired similarly to a refridgerator where you install a receptacle in a box and get a plug set for that appliance and simply plug it into that receptacle.. Feel free to respond to this with any questions or if I confused you.. I'll get you thru it.
Hope this helps..
Posted on Aug 31, 2008
Will run thourgh cycles but only a little water will go in
Check fill line for a kink, (remove kick panel on bottom of dish washer)
If no kink then replace fill valve. Unplug dish washer fill valve is where water line is hooked on.
Aug 10, 2014 | Frigidaire Dishwashers
How to repair my kenmore dish washer not powering on but shocked me before it shut down for good ?
it sounds to me as though you may have a bare wire giving a direct short to the system.therefore by having a hot wire grounding out on the dishwasher body, it is running that current to the dishwasher body where if you touch the dishwasher you will recieve a shock.this also doesnt allow the electricity to go to where it is needed to power your appliance.
May 20, 2014 | Kenmore Dishwashers
I need to know what size breaker and what size electric cable should be used in the installation of this Ingersoll Rand SS3L3 3hp motor. I've ordered the compressor but it is supposed to take awhile before...
I am assuming that you will be hooking the air compressor to a 240 volt line...
That motor will draw about 18 amps...... so a 20 amp line will be too close to that draw....
so you will be looking at a 30 amp line...
For that you will need to run a 10gauge three wire with ground on a 30 amp two pole breaker...
that will serve you for up to about 100 feet of wire... if you are running the wire farther then that you will need to up size the wire to 8 gauge so that the motor can draw enough to get started...
heatman101
Jan 11, 2011 | Ingersoll Rand Single Stage Electric...
My dish washer dose not start, it keeps yieling "
Hi enasammar, First thing to do is to reset. Merely unplugging the power cord from the wall socket for 4 hours, then power up again.The purposed of unplugging is to dissipitate the stored current in the memory IC thats control the unit to hang up, so it will gone. Take out all inside the unit and clean,then turn on . If still not working give me the model number so i can find the schematic diagram for that unit. Hope it may helps.
Regards: VOTIT
Dec 03, 2010 | Frigidaire Dishwashers
We have Frigidaire 24 in. FDB1050REC dishwasher. The control panel has no power; no lights and nothing works. This problem started after a power outage. All circuit breakers in house ok and other outlets...
more than likely fuse is gone in plug. take dish washer out. change fuse in plug. if it doesnt work get extension lead and run it from a socket that definatly does work and plug washer into that. if nothing then its internal.
Jan 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Not enough water Pressure to clean dishes, 6yr old Bosch
Replace the pump, if you go through the trouble of repairing the pump and all the disassembly and then more problems will probably ensue. As far as location it is usually located under the washer. Accessed through the front service panel. Make sure you follow all safety procedures #1 being unplug the washer or turn off breaker prior to proceeding.
Feb 13, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Dish washer door leaks
This sounds like a case of the water rising too high in the machine. If your unit has a float to control the water level (located in the wash area), it is likely stuck. Free it by letting water into the machine and then exercising it to get the 'goo' out. If it has a pressure switch located in the motor area, clean out the line.
Feb 10, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Fridiare dish washer
Sounds like a blown thermal fuse. Most dishwashers have a thermal fuse mounted on or near the control board inside the console. There should also be a tech sheet inside the lower panel under the door that can help guide you. The thermal fuse should read a short. If it is open, it is non-resettable and must be replaced. I hope this helps you.
Jul 21, 2007 | Frigidaire 18 in. FDR252RB Built-in...
Open Questions:
Dishwashers Logo
74 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
