Question about Fisher and Paykel Dishwashers
We just moved in to a new house and the dishwasher's spinning piece was dismantled. We dont know how to set it up and we have a few different pieces that dont really match. please help! Thanks
  • 706 Answers
Hi Lorainne.. You ,may be able to get the user manual at this link http://www.fisherpaykel.com/global/customer-care/product-manuals.cfm Should get you steered in the right direction... Hope this helps..
Posted on Aug 31, 2008
New AEG dishwasher wont fit in existing space that housed our old Favorit 44050 VI
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
d8c6be34-1c2a-482c-8f06-f609e72b619c.jpg 9cc1da12-62a1-4b9c-9bc2-5a2b06e4845b.jpg
Mar 11, 2014 | AEG 24 in. Favorit 44050 Built-in...
Water fills but no spray action
Check the piece that connects the motor to the impeller. The original piece is plastic and can get stripped allowing the motor to spin without moving any water.
Nov 30, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
Need directions/advice on dismantling suncast 10x10 shed model A0
You can dismantle this thing, you can also have it moved on a flat bed wrecker, how far are you going? I would try to get it apart panel by panel, not piece by piece, but wall by wall. It might be possible, but when it goes back together, you might need some new fasteners and brackets here and there. And yes, it is worth it. Hope this helps.
Jul 03, 2010 | Suncast 10' X 10' Storage Building
Ge dishwasher dont wash
i think this is a simple answer;;your dishwasher has a piece of glass in the out pump or something else.remove and you will find it will be ok adriqan.;;;;
Jan 20, 2010 | Dishwashers
My washer (ALW880QAW) agitates but does not spin. I took off the front cover and the found a black circular piece lying there (What it goes to I do not know). The belt looks okay. The motor goes in spin...
That is the drive coupler and it has worn out. You can order a replacement set that comes with two plastic retaining pieces that slide onto both your transmission and engine and also a rubber piece that goes in between these two plastic pieces. You can search many places to find out how to replace this part. I just ordered a set and shopped around a bit and mine was $20 after shipping.
Nov 29, 2009 | Amana ALW880WH Top Load Washer
My Kenmore 13593 dishwasher has stopped washing properly. It seems like the spray nozzles are not spinning. Almost as though there is not enough pressure or their is an internal leak. I have plenty of...
Look for plugged screens in the pump area... House water pressure has nothing to do with washing pressure as house water only fills, then the dw pump takes over...
Sep 20, 2009 | Kenmore 13593 Stainless Steel Built-in...
Dont know how to clean the dishwasher
go to the dishwashers brand site,click help for your solution.
Jan 05, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
The blade will not spin when the top piece is secure, & I the inside will not come out to clean
There is a roll pin under the flywheel, I you can get the basket off then you pull up on the flywheel , It is the last part before the motor housing. Once you have that off I think you may find that pin is sheared off. It is a common automotive or bearing house part. push out the old and push in the new pin and away you go. The new pin shoud protrude about 3?16 " on both sides of the pin. I hope this helps.
Dec 27, 2006 | Acme 6001 Juice Extractor
Dishwashers Logo
53 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
