Question about Canon PIXMA iP4000 InkJet Photo Printer
Yellow ink not printing
I tried that first...ALL the tape is off and I have re seated it several times...still no yellow...all the other inks are fine...
  • 1 more comment
  • marycresteds Aug 31, 2008
    Hi and first...thanks for your help ! It is a Canon Pixma IP3000...It was printing fine and then the yellow ink ran out and I got a new one, put it in and nothing...so I thought maybe the ink was bad, so I got another one and the same thing..all the paper is off the cartridge and I have re saeted it several times,,,how frustrating ! I have deep cleaned it several times and get the same ..only black, cyan and magenta...
  • wyee Sep 10, 2008
    I cannot get any blue ink to print. I have done MANY deep cleaning cycles.
  • Roberta Smith
    Roberta Smith May 11, 2010
    As this ask me thing does not show it please let me know the brand and model number again i'll see if i can help you with this issue.
    Brigadier General:
  • 5,158 Answers
Didn't mean to take so long.
here is the website for your printer. manuals and drivers and faq's as well. something there should help you. if you still have no success please get back to me.
http://www.canon.com.au/products/printers/colour_bj_printers/ip3000.aspx
Robert
Please rate this solution thanks
Posted on Sep 02, 2008
I just changed all of the ink cartriges. Now the magenta and Cyan are not functioning....nothing. Everything is yellow and black, I cleaned the print heads twice, just wasting ink. I tried to align the...
If it worked before changing the ink-cartridges, then it probably is _NOT_ a case of "clogged" ink-jets in the print-head.
Did you remove the plastic "sealing" tape from the new cartridges, before you installed them?
If not, then no ink can leave the cartridge.
Which model of HP printer? Maybe, you got a "dud" of a new ink-cartridge.
Take it out.
Take an old, thick, section of newspaper, and lie it flat on your table.
Dampen a paper-towel, and put it onto the newspaper.
Touch the ink-cartridge to the paper-towel -- it should "bleed" some ink onto the towel.
Not much ink, but the newspaper is there to protect the surface of the table.
If no "bleeding", then the ink-cartridge is the problem.
May 21, 2011 | HP Office Equipment & Supplies
Hi, I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the cartridge and all other colours are working except Yellow. I would appreciate any solutions you may be able...
I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the particular cartridge and all other colours are working except Yellow. I have cleansed the printer several times and tried with new Yellow ink cartridges with new chips, but nothing helps.
What should I do?
Jan 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
I have a Brother MFC 3340CN and 1940CN,fax,print,copier I was working fine and then all at one message was yellow out of ink please replace and start again. It has a brand knew yellow ink cartiage in it...
The ink that is given to you when you buy a new machine is not the same as if you went out and bought ink. The "starter" ink cartridges are not filled completely (that is a marketing gimmick to get you to buy more quickly). When you say "NEW" do you mean "new, never been used", or "new, just got it last week"?
If it's never been used, be sure that you have removed the protective tape from that cartridge. If it's been removed then the cartridge its self could have a problem or the machine could be at fault (not correctly reading the ink). You choices are to return it to where you got it, or buy a yellow cartridge and replace it.
If it was working and stopped after a very short time (a week or two) I would get a new yellow and try it.
For your sake I hope it's the protective tape was forgotten, it happens quite often.
Dec 23, 2010 | Brother MFC-3340CN All-In-One InkJet...
My canon pixma ip1300 is showing service error 5100, not printing and yellow light blinks five times thanks in advance..........
Solution: Install the print head and ink tanks correctly iP3000 / i560
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Power on the printer.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
    Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
  5. Remove the print head from its package and remove the orange protective cap.
    <1> Electrical Contacts and Print Head Face's Nozzle Area
    <2> Ink Supply Filters
    Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
  6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
    Next, install the ink tanks.
  7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
    Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
    <1> Removed correctly
    <2> Removed incorrectly
  8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
    Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
  9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
  10. Close the inner cover and top cover.
    Note: Check that each ink tank is installed in the correct position:
    Properly installed:
    Improperly installed:
    <Left Image> The M ink tank is not fully seated.
    <Right Image> All ink tanks are not fully seated.
Dec 03, 2010 | Canon PIXMA iP1300 Printer
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
Printer says out of ink and I put new cartrages in I took off the tape, have put them in and out several times to make sure they are in properly. I have restarted printer and have shut printer off and...
Sometimes when the tape is removed a small piece tears off and remains stuck on the cartridge. Its' happened to me once or twice. remove the cartridge again and check carefully under a bright light. If it is clear of tape there may be dried ink in the nozzel. Use a dampened Q-tip to remove any ink residue.
Worst case would be a clogged print head. After trying everything else and you suspect it may be the print head, you can get a print head cleaning kit online for about $10.
Jan 18, 2010 | Office Equipment & Supplies
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Don't know how to move the cartridges to replace the ink.
Please follow the instructions below to ensure correct installation:
  1. Lower the printer's output tray and open the top cover.
  2. Connect the power cable to the printer.
And switch on the printer.
The print heads will now move to the replacement position. If they do not move to a change position press the Red ink button on the printer.
  • Lift up the ink cartridge clamps.
    Before you open the new ink cartridge package, shake it four or five times. Then remove it from the package.
    Do not touch the green chip
    on the side of the cartridge. This can damage the ink cartridge.
    Remove the yellow tape from the bottom of the ink cartridge.
    You must remove the yellow tape from the cartridge before installing it; otherwise, print quality may decline or you may not be able to print.
    If you have installed an ink cartridge without removing the yellow tape, take the cartridge out of the product remove the yellow tape, and then reinstall it.
    Do not remove the transparent seal from the bottom of the cartridge or the label on the cartridge; otherwise the cartridge may become unusable or ink will leak.
    Place the ink cartridge into the cartridge holder with the bottom down. Then push down the ink cartridge until it clicks into place.
    Repeat steps 4 to 6 for each ink cartridge.
  • Close the ink cartridge cover and press it until it clicks into place
      If you find it difficult to close the cartridge cover, make sure all the cartridges are firmly seated. Press down on each cartridge until you hear it click into place. Do not attempt to force the cover closed.
    1. Close the printer cover and press the ink or start button to begin charging the system. Charging can take up to three minutes and is complete when the power light stops flashing.
    While the ink system is charging do not switch off the printer.
    Sep 16, 2008 | Epson Stylus 880 InkJet Color Printer
    Blank pages coming out of i850 with new printhead
    Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
    I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
    Issue: Certain colors are missing or no ink prints on the paper
    Solution: Install / replace the recommended ink tanks correctly i550 / i850
    Untitled Document How to install / replace the ink tanks
    The ink tanks suitable for the printer are as follows;
    Black Ink Tank BCI-3eBK
    Cyan Ink Tank BCI-3eC
    Magenta Ink Tank BCI-3eM
    Yellow Ink Tank BCI-3eY
    Note: There are two ink tank label designs.
    Operation procedures are shown with label design A.
    labelsa.jpg Replacement Procedure
    1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
    2. Remove the empty ink tank by pushing the tab on the ink tank.
    Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
    (The image is an example using i850.)
    3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
    Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
    Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
    (1): Correct
    (2): Incorrect (where the arrow indicates)
    4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
    5. Insert the new ink tank to the print head by holding it at a slight angle.
    Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
    6. Press down on the top of the ink tank until a click sound is made.
    7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
    May 07, 2008 | Canon i850 InkJet Photo Printer
    Yellow Ink Won't Print
    what is the yellow ink cartrage level is it empty
    Jan 08, 2008 | Epson Stylus CX3810 All-In-One InkJet...
    Canon PIXMA iP4000 InkJet Photo Printer Logo
    old marine
    old marine
