Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Dispenser light very dim
Replaced door dispenser light bulb ( appliance bulb) twice each time when light is turned on, the filiment in the bulb is very, very dim....replaced with another new bulb,...same problem
  • Anonymous Mar 24, 2014
    Light bulb goes out occasionally when door is opened
Put a new York Bulb for your tired computer. Sorry! Can't answer this.
Posted on Sep 23, 2008
How can I fix a dim light bulb on an ice dispenser?
The dispenser bulb looks similar to a c7 christmas bulb or night light bulb but they are not the same. The dispenser bulb on some are 6 volt and some are 12 volt. The night light bulbs are 120 volt and will light very dim. Make sure you got the correct bulb from an appliance part dealer. They will need your model number of the fridge. Or check on line parts stores like www.vvapplianceparts.com.
Mar 04, 2016 | GE Profile Arctica 25.4 Cubic Feet...
Headlights wont work on dim, only bright
Check your head light bulbs, your truck has the dual filiment headlight bulbs one per side which does both high beam and low beam, 9007 bulbs.
If the low beam filiments are burned out only the high beam will work.
Also look into finding out if the headlight switch is gone bad.
The headlight module and or drl module maybe defective.
Jan 24, 2014 | 1996 Ford Ranger SuperCab
2001 Mirage 1.8. Battery and brake light goes on very dim when i press the brakes. Once driving it goes away. Went to three different places to get battery and alternator check both are good with...
Most likely there is a short in the wiring for your brake lights. Modern automotive electrical systems are very complex, if you're not experienced with automotive or electrical repair it may be best to take the car to a reputable repair shop. Parts stores can not diagnose or repair this type of problem.
Mar 08, 2011 | 2001 Mitsubishi Mirage
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Bad turn signal
The turn signal flasher appears defective. Chk bulb in tail light for burnt short fat filiment.
Jun 13, 2009 | 1995 Chevrolet Caprice Classic
2002 Chevy Blazer, rear brake lights do not work but the third light above the window does. Replaced bulbs and still not working I have the same problem got a fix it ticket the other.  Did you guys...
Trace the wiring as it comes from the laft and right brake light. May have to remove the brake light covers. Sounds like a crimped or shorted wire leading to the brake lights, possibly a loose or broken ground wire. One of the wires leading from the fuse block to the rear oif the vehicle could also have been damaged if the door sills have been removed by someone earlier to install things like speaker wires, etc. Also check to see if you have tail lights and directional signals.
When you replaced the bulbs did you get bulbs with double filiments - one acts as the tail lights, the other serves as the brake lights (both inside the same bulb). Compare the ID numbers on the bulbs with those which are required for this vehicle, but you should clearly see two different filiments inside of the bulbs when viewed from the side.
Jun 01, 2009 | 1998 Chevrolet Blazer
Fuse for trailer right turn signal and brake blows intermittently
abad ground on that tail light unit could affect current load when turn and stop are used simultaneously. Although one side only is affected make sure of good grnd between trailer and tow vehicle. focust on the tail light unit in question. Replace the bulb. though rare, bulbs have been known to be the problem. If the bulb is breaking filiments ck the filiment orientation. filiments last longer in vertical orientation, where horizontal permits vibration to break the heated filiment when brake is applied.. good luck and let me know if This helped or not.
Apr 26, 2009 | 2003 Chevrolet Silverado 2500HD
GE Profile Refrigerator will not dispense ice.
see http://applianceguru.com/view_topic.php?id=13243&forum_id=1&jump_to=76889
Feb 21, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
446 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
