Question about Brother XR-65t Mechanical Sewing Machine
Brother machine xr65
I was sewing and I hit a pin. The metal that holds the needle in place fell off and the thread glide fell off. The needle clamp won't stay on nor will it hold the needle in place.
5 Suggested Answers
MakikiChris
  • 84 Answers
SOURCE: brother XR65 twin needle threading
hi roscoepc1.....The threading pattern is identical to single needle. The only changes are that you now are threading 2 spools of thread, one thread for each needle. The only change that I reccommend, but not neccessary, is that while threading through the tension dial, lay your threads between separate discs, and not together between the same pair of discs. Your tension dial contains either 3 or 4 discs.......please update your post if you have any further information or questions.....good luck my friend
Posted on Aug 05, 2007
mohammed387
  • 1952 Answers
SOURCE: My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Posted on Aug 31, 2008
SOURCE: HI I HAVE A BROTHER
needs a new needle clamp screw & possibly the needle clamp too
try sewingpartsonline.com
Posted on Jan 12, 2011
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
My Brother XL5130 Needle Clamp Body felt out while I am sewing something. I do not know what is missing. I found 4 things in my hand Clamp Body, Pin,Clamp side screw & threads guide. some one plea
There is a hidden screw just that looks like a hole beside the screw that hold the needle... loosen it with # 8 allen key (pretty small) then you put the curved wire back in its hole, then you can put it back on the arm, then screw back the allen screw as tight as you can, this should do the trick worked for me ... I was tring for days to fix it back on but wouldnt go in...this invisible screw was to tight... Hope it helped !
Jul 19, 2012 | Brother XL-5130 Mechanical Sewing Machine
I have a Brother XR-65. The needle bar fell out as I was sewing. I need a repair manual or some instruction on how to secure the needle bar in the machine. I have the bar itself and a pin sized piece of...
This was happening to me also - you have to tighten a different screw than the one that holds the needle in.
http://www.sewingpartsonline.com/needle-clamp-screw-brother-ls-2125-sewing-machine.aspx
My husband thought the screw was missing - it is actually a plastic screw with a hole in it for a tiny allen wrench.
You can see it in this picture also
http://www.sewingpartsonline.com/needle-clamp-babylock-brother-xz0001051.aspx
If you look at the photo of the screw I attached, you can zoom in and see it has a hexagonal hole.
It is above the flat head needle clamp screw (the one that holds the needle in)
It is REALLY annoying that this screw is mentioned nowhere in the manual, and the hex allen wrench is not included with the machine.
Kind of an important little detail, considering it holds the needle assembly together... you'd think that they would have told you about it.
Sep 09, 2011 | Brother Sewing Machines
HI I HAVE A BROTHER XL-5011, the clamp that holds needle in place fell off whilst sewing now it won;t stay on thnxs
Jan 11, 2011 | Brother Sewing Machines
I have a Bernette 50 sewing machine....i was sewing velcro....the screw assembly on the post where the needle goes into fell off and the thread guide fell off it....i can't tell if it is broken or just...
That can be tricky. Some thread guides and needle clamps have to be assembled and then slid up into place with the needle screw holding it together. Some have a set screw to hold it.
Jun 27, 2009 | Bernina Bernette 75
this sounds like the needle guard it is usually held on by the same screw that holds the needle clamp it should fit so that it comes across the needle at the front to stop your fingers being sown but not interfere with the needle try turning by hand before turning back on.
Jun 05, 2009 | Brother XR-65t Mechanical Sewing Machine
Needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Jan 30, 2009 | Brother XL-5130 Mechanical Sewing Machine
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Brother XR65 twin needle threading
Aug 05, 2007 | Brother XR-65t Mechanical Sewing Machine
Brother XR-65t Mechanical Sewing Machine Logo
59 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
