Question about Brother XR-65t Mechanical Sewing Machine
My needle broke and a piece of metal fell out of machine
I was sewing and my needle broke. The metal that holds the needle in place fell off and another long piece of metal fell out. The long piece is part way straight, and then curves around perpendicular to the strait part doing a 3/4 turn. I am not exactly sure how to put it back together. I was sewing and I hit a pin. The metal that holds the needle in place fell off and the thread glide fell off. The needle clamp won't stay on nor will it hold the needle in place.
  • 8 more comments
  • emtmom9 Sep 01, 2008
    tat solution does not work. it is not simply the needle! IT IS TE NEEDLE HOLDER (THE PIECE OF METAL) & the thread guide FELL OFF! I know how to position the needle. doesn't do muc good if holder won't stay on machine.
  • emtmom9 Sep 12, 2008
    The solutions are of no help, thus far. All pieces there. Have been sewing for many years. never came across this problem before. But this is my first Brother sewing machine & now probably my last. a machine should not fall apart doing something as simple as changing a needle.
  • Beth Sep 26, 2012
    just wondering if anyone figured out how to get the piece back together, i have tried n tried to get it back together and can not figure it out so if anyone did get theirs back together please let me know
  • kaseyd3332
    kaseyd3332 Nov 16, 2012
    I have the same situation. I have had the machine for years with no problems. For no apparent reason the whole metal piece that holds the needle fell off. Reading on line it I seen another machines book reference that it means the metal housing that holds the needle is damaged. So I'm looking for replacement parts and will update what happens.
  • kaseyd3332
  • Anonymous Mar 14, 2014
    the mechanism that hold the needle in came loose therefore the thread secure piece came off too. an allen wrench will tighten the needle mechanism but how do I secure the thread securing unit.
    I secured the needle with the clamp and the allen wrench but the twisted wire that holds the thread is not secure. How do i secure that or did is shear off?
  • Anonymous Mar 16, 2014
    Needle bar fell off
    singer 237 The needle clamp assembly with the small metal part inside won't stay in place to insert the needle, What can be done?
  • Anonymous Mar 31, 2014
    I have a Pfaff Creative 2 new machine and when I attempt to change the sewing foot it won't snap in or attach to the metal piece that holds the foot ; it falls out
    President:
  • 1,952 Answers
Just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Posted on Aug 31, 2008
  • 421 Answers
Is there a screw missing that got pulled out when it came off? tip the machine and see if any other pieces may have fallen in or around should be quite simple to put back together -jeff please rate
Posted on Sep 01, 2008
  • 2,071 Answers
  • LORETO LACARON
    LORETO LACARON Aug 31, 2008
    Just click below for the guide how to put the needle ;
    Sewing Machine 101- Sewing For Dudes (and Ladies) No. 2: Stitches ...
    Anatomy of a Sewing Machine. 1) Bobbin winder 2) Spool pin 3) Thread guide 4) Tension Knob 5) Foot and needle 6) Bobbin housing
    regards,
  • LORETO LACARON
    LORETO LACARON Sep 07, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
Metal boot shape piece goes inside needle bar then needle they keep falling out. Metal fell out trying to change
Would you please say what model you have? I gather that there's now a problem with your needle clamp, and it won't hold needles? Those clamps can be replaced inexpensively--you just slide the old one off and the new one on--but I could be more specific about where you can buy a replacement if you supplied the model number.
Jul 02, 2015 | Singer Sewing Machines
MY BOBBIN CASE FELL OUT TWO PIECES HOW DO I PUT IT BACK TOGETHER
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in.
Feb 22, 2011 | New Home HF-2022
Inside the walking foot a piece of metal broke
I would contact the manufacturer and ask about it. Maybe a replacement part is available.
May 31, 2010 | Sewing Machines
The thing you put the needle in and their is a wire thing that goes in there...that piece fell out and needle won't stay in...it's a brother XR-35
What fell out was the needle clamp gib - a small wedge-like part that presses on the needle to hold in place.
You may be able to get it repaired or replaced.
Search online for parts, or ask a sewing machine service tech for an estimate for having the machine repaired.
Mar 19, 2010 | Sewing Machines
I have a Bernette 50 sewing machine....i was sewing velcro....the screw assembly on the post where the needle goes into fell off and the thread guide fell off it....i can't tell if it is broken or just...
That can be tricky. Some thread guides and needle clamps have to be assembled and then slid up into place with the needle screw holding it together. Some have a set screw to hold it.
Jun 27, 2009 | Bernina Bernette 75
this sounds like the needle guard it is usually held on by the same screw that holds the needle clamp it should fit so that it comes across the needle at the front to stop your fingers being sown but not interfere with the needle try turning by hand before turning back on.
Jun 05, 2009 | Brother XR-65t Mechanical Sewing Machine
Brother XR-65t Mechanical Sewing Machine Logo
899 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
