Question about Frigidaire ATF6000ES Front Load Washer
Washer moving while on spin cycle
I have adjusted the legs out. the washer spins fine when empty, but when a load of clothes is in the washer shake and moves violently across the floor its new so im looking for answers, please help
  • 1 more comment
  • smoove407 Aug 31, 2008
    help please
  • smoove407 Sep 01, 2008
    thanks i have fixed the problem, there were 4 bolts and plugs that should have been removed when installed, well they were not .i removed them and all is well. thanks again
  • Anonymous Oct 28, 2008
    I had the same problem with a brand new Frigidaire front loader. The shipping bolts were the culprit. All is fine now.
  • 639 Answers
Friend,
ngfam1 At your service!
The washer should be leveled with a spirit level.
If it is not corrected after this measure!
remember you have a full warranty for one year and they will come out a remedy the problem with hands on service! for FREE!
Then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
  • Neil
    Neil Sep 02, 2008
    smoove407
    CALL THE DEALER AND TELL HIM THAT HIS GUYS DID NOT FINISH THE SETUP AND FORGOT TO TAKE OUT THE SHIPPING BOLTS!
    THEY ARE SO THE WASH TUB CAN NOT MOVE DURING TRANSPORT FROM THE FACTORY TO THE WAREHOUSE AND DEALER!!!!!!!
    WE HAVE A 65 YEAR OLD APPLIANCE RETAIL BUSINESS AND I WOULD WANT TO KNOW THAT THE GUYS DID NOT DO THE JOB RIGHT!!!!!!!!!!!!!
    BLESS YOU,
    NGFAM1
    PLEASE GIVE ME THE BEST RATING BEFORE YOU SIGN OFF AT FIXYA.COM
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Excesive Shaking during spin cycle
Your washer has self adjusting rear legs . Tilt the machine foreward and look at the back legs . If one is stuck in , use a screwdrive and pry it out till both legs are in the out position . Set washer back down slowly and the rear legs will automatically adjust .
May 02, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Basket rocks loudly during spin cycle. Does it on every load so I don't think it is a balance problem.
i just got a used whirlpool washer and as soon as it went on the spin cycle it started shaking bad! i adjusted the legs and moved the clothes around evenly! still doing it?? i would like some advice please!!!!!!!!!!
Mar 13, 2010 | Maytag Washing Machines
Front Load Frigidare washer bouncing on spin, very bad!!!
Hi, not sure if you have solve this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
Jun 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Vibrates and moves during spin cycle
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Dec 27, 2008 | Admiral AW22 Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Our washer shakes badly at the spin cycle
Please look in the back see if the shiping bolts /rods have been removed it should show you in the manual about this
Jan 03, 2008 | GE WCVH6260F Front Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore Washer won't agitate, spin or drain
It's not your exact model but does have some good information about the possible causes.
http://www.shopyourway.com/questions/1099421
Apr 07, 2017 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
388 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
