Question about Samsung Digimax 201 Digital Camera
Samsung Digimax 201 and INFINEON 128mB SD Card
Bought a Samsung Digimax 201 and INFINEON 128mB SD Card. To get pics from internal memory to pc easy. to get pics from SD card when in camera, wouldnt do it when f: screen eventually opens theres nothing on it
    Master:
  • 542 Answers
The disc reader works fine and, yes, it is an obvious defect even though Samsung won't admit it. I just figured $20 to workaround the problem was better than going through the hassle of returning the camera, picking out another brand, and plunking down the extra dollars another camera would cost. The deal on the Samsung was good and I like the pics I've taken so far. Any comparable camera would probably have a higher price point anyway. I also was guessing that it might be some conflict with the software on my PC and that any other camera I bought might also bring trouble. Then I came here and found out it wasn't just my problem, despite what Samsung says.
Posted on Sep 12, 2005
    Master:
  • 542 Answers
Had a similar problem running windows XP, it couldn't read my sandisk SD card on a usb sandisk imagemate reader/writer. The solution on Microsoft's site was worthless, having already applied all XP patches. Fortunately, I tried accessing the SD card under windows 2000 and it worked fine, so I formatted the SD card in windows 2000 and now it works fine in XP.
Hi how do i formatt my camera card
From page 63 in the manual.
Format
Internal memory format : Remove the SD memory card to format the internal memory.
SD memory card format : Insert the SD memory card to format the SD memory card.
All the files in the memory are deleted by the [FORMAT] function.
Before formatting the memory, it is advisable to copy important data onto other media as back-up
e.g. floppy disks, hard disks, CD etc.
1. Turn the camera power on.
2. Select the PLAY mode by rotating the mode dial.
3. Do not turn the LCD monitor off.
4. Press the MENU button to display the menu on the LCD
monitor.
5. Press the UP( )/ DOWN( ) button and select [DELETE].
6. Press the SET( ) button and the sub menu will display.
7. Select [FORMAT] by pressing the UP( )/DOWN( ) button
and press the SET( ) button
8. Select [NO] or [YES] and press the SET( ) button.
[Selecting NO] : The image will be displayed on the
LCD monitor.
[Selecting YES] : A [PLEASE WAIT!] message is
displayed and all of images are
deleted.
Link to manual:
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=2702&prd_mdl_cd=EC-D201ZSBA/E1&prd_mdl_name=DIGIMAX%20201&srchword=digimax%20201
Jul 05, 2011 | Samsung Digimax 201 Digital Camera
I need to transfer internal memory photos onto memory card
First need to take off the SD card; default settign make the SD card as main stored when this is inside the camera.
Take off the SD card and send the internal memory pics at pc folder (use USB connection); insure that the pics are in this pc folder, them delete the files in "internal memory".
Take on the SD card inside tha camera and send pics from pc folder at camera, confirm that the pics are there.
Hope helps.
Apr 28, 2011 | Fuji FinePix A850 Digital Camera
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
Ive got a Samsung Digimax L70 and I have been trying to clear the actual camera's memory. I have uploaded photo's from the SD card but 400 or more photos remain on the camera and I just can't access them...
Wow! You have 400 pics on the internal memory. That must be some huge internal memory. Anyway, to delete them, remove the card from the camera...go into the menu and find "format"...follow the on-screen instructions.
Jan 19, 2010 | Samsung Digimax S800 Digital Camera
Can i move pictures from internal memory to an SD card??? samsung digimax D53
im not sure on yours but on mine there is a option for copying a picture under the menu just go to the pic you want on the externa. memory and go to your menu find copy picture and then it will copy to it
May 01, 2009 | Samsung Digimax D53 Digital Camera
Transfering problem
Your camera has no internal memory so please buy a card reader and transfer your images into your pc and your next memory card
Oct 15, 2007 | Samsung Digimax L60 Digital Camera
Digimax L60 will not recognize my card
Your Digimax L60 will also recognize your SD card please select the option to save pics
In camera or in memory card. This time your camera work on its internal memory.
Oct 11, 2007 | Samsung Digimax L60 Digital Camera
SD CARD
If I remember correctly, when you insert an SD card, it "hides" the camera's internal memory. There should be an camera option for copying the files from the internal memory onto the inserted SD card. If not, you could try connecting the camera to your computer with the SD card removed, in order to access the files in the internal memory.
Feb 10, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax 201 Digital Camera Logo
96 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
