Question about Olympus Camedia C-750 Ultra Zoom Digital Camera
Blurry indoor photos C-750
I am having trouble taking indoor photos, with flourecsent lighting. They all come out blurry. Anyone know how I can correct this? I also cannot take clear photos of my kid's sports. It seems that the shutter speed just isn't fast enough even on sport setting. How do I adjust shutter speed on this camera?
    Master:
  • 852 Answers
Use A mode and set the biggest aperture you can set (f3.5 ?) this this will then allow the camera the fastest shutter for the availbe light. In low light conditions this still may onlt be 1/4 sec which is still to slow for hand holding a camera. Best you turn your flash on huh.
Posted on Sep 12, 2005
Extreme overexposure
Unfortuneately the lens on the replacement camera will probably need to be changed.
Jul 08, 2012 | Canon PowerShot SD890 IS Digital Camera
Hello! i am taking still pictures and they seem to come out blurry... even when I dont have the flash on... can you please help?
The flash is suppose to help with the lighting situation in order to lower the chances of you taking blurry pictures. Usually indoor pictures must have the flash go off in order to get clear pictures. If your outdoor pictures are also coming out blurry then you probably have some problem with the lens. My first suggestion is for you to go into the menu and reset all functions to default. You will have to read the manual to find which menu it is in, but I guarantee you that it is in the camera menu. If the reset does not fix your problem then the lens is probably out of position or damaged in some way. You would need to send into an authorized service center for repairs if this is the case. I know that Photo Tech in NYC is authorized for Nikon repairs. www.phototech.com is the contact info.
Good luck
Paul
Jun 30, 2011 | Nikon Coolpix S4000 Digital Camera
When I try to take a photo indoor with the flash turned off, the picture is blurry. How do I fix it so that my photos are not blurry any more?
Since there is less light, the camera leaves the shutter open for a longer time....plenty of time for you to move the camera slightly enough to blur the pictures. Here are some suggestions: 1. If the camera has some version of "shake control" or "image stabilization", turn it on. 2. Set the ISO to a higher number. 3. Turn on more lights inside if possible. 4. Use a tripod or set the camera on a firm surface.
Apr 24, 2011 | Fuji FinePix F460 Digital Camera
blurry pictures often comes from the slightest movement when the pictures is snapped.
Don;t know if that is your problem or not try a photo tripod and see if that helps or check your trouble shooting area of your amnual. if you don't have the manual go to this site for any type of manual::::
http://tv.manualsonline.com/search.html?q=vr+5940&submit.x=35&submit.y=14
Aug 28, 2009 | Cameras
Blurry pictures after I have had no trouble in the past
If this is happening only in low-light situations when the flash is not on, check your manual to turn the camera's high-sensitivity feature on. Or change the ISO to the highest setting (1000 is good) for these pictures. That should reduce blur and shake. Of course, putting the camera on a tripod or beanbag, or resting your elbows on a solid surface, will have the same effect.
Jun 05, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Blurry indoor results- using flash
Built in flash units on digital cameras are only meant to be used out to a distance of 6-12 feet. When taking photos of events ie graduations, sporting events, concerts you need to do two things. 1). Change the ISO setting on your camera. This is the same as the old film speed ratings the higher the number the more sensitive the camera becomes. try ISO 1600 or above in low light. 2) You have a mode setting, set it for the type of lighting that is in the space you are in, incandescent, flourescent or whatever, it's easy to do. and finally 3) Turn off your flash! When your flash is on your camera closes up the aperature and takes the picture at a higher rate of speed in anticipation of reflected light off of nearby objects, so your pictures will be darker and blurrier with the flash on.
Even high grade professional flashes only work out to 20-30 feet so they won't help you. Read your cameras manual on taking pictures in low light conditions. It will give you all of the above in great detail. You have a great camera but you need to learn how it works, don't give up on it.
Jun 02, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Blurry Photos when using indoor or auto mode on Olympus IR-300
make sure lens is clean and be sure to use flash indoors, try using a tripod or setting camera on something and see if the results are any better
May 14, 2009 | Olympus i:robe IR-300 Digital Camera
Indoor pictures
Dear Kim
Sony Cybershot works on technology of where is checks the srround light, if light is fine (like in Sun or outside) phots are fine. solution to this either replace flash or put some big light on  while taking photos
thanks
Oct 21, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Pictures out of focus indoors
Maybe your camera has a problem with flash unit. Replacing the flash unit can solve the problem. Part number of the flash unit is: A7113088A. If you need more help, please advice. Arpi
Mar 17, 2007 | Sony Cyber-Shot DSC-P93 Digital Camera
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Olympus Camedia C-750 Ultra Zoom Digital Camera Logo
110 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
