Question about Fisher and Paykel (IWL12)
F & P Smart Drive 085
Hi, my machine has the lights showing and can select to change but the start button wont work to start the machine. Is it likely to be an expensive fix or can i do something or is it better to get a new one? Any helpful information you can assist me on please?
  • 639 Answers
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
Kelvinator 085 Smart Drive. Why won't it start?
kelvinator smart drive 085 washing Questions & Answers ...
www.fixya.com > Forum > Tags
smart drive 085 not filling with water when start button depressed Could be the magnetic latch on the lid that tells the machine when its closed you can by pass
Sep 30, 2015 | Washing Machines
Kelvinator smart drive 085 washing
Your lid magnetic reed switch could be faulty.
May 09, 2014 | Fisher and Paykel Washing Machines
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
Fisher and paykel smart drive 703 top loader, lights go on but pressing them even to start does nothing not start or let me change the size of the load ;(
Hi, just read your posting.Now the possible fault could be your display board.When you turn the power on to the machine from the power point do all the lights come on and you hear an audio beep beep , then the lights go out ?If that happens, then do you push start and can not select anything else like water temp or load size?Or do a series of lights light up and it beeps indicating a fault code after you have pushed the power button? Please reply and I can guide you throe step by step the process needed to fix this problem.
Jun 05, 2010 | Washing Machines
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Kalvinator smart drive 085 not filling with water when start button depressed
Could be the magnetic latch on the lid that tells the machine when its closed you can by pass the switch just dont open it whilst its going
Jul 12, 2008 | Washing Machines
When filling my F&Paykel washer the water is not a constant flow, it is filling in 'spurts', ie stop/start/stop/start etc...... I have tried cold, hot & warm water, all combinations of temp are...
You most likely have a smart water temp sensor on your machine. It makes sure you have the proper water temp to dissolve your detergent. Even when set to cold, it will add some hot water. It sounds like your machine is working properly. If you feel you are haveing a problem check the water temperatures in your owners manual and then check them with a thermomater in the washer. If they are not correct you may have a bad temperature sensor. Good Luck and I hope this helped. Mca0824@aol.com
Apr 30, 2008 | Washing Machines
Washing Machines Logo
244 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
