Question about Cameras
Vivitar 636AF Flashgun
An "auto focus illuminator" flash gun by Vivitar. Need schematic to install a shoe for use with Canon cameras. Have checked all my known sources, none have it. Any clues much appreciated.
I do have the same unit that I am currently using on a EOS 10D. It works fine for me. It lso operates on my EOS 350D but does not flash off quite bright enough on this camera in very low light.The unit was previously paired with a canon EOS 5 film. You can contact me at a.blast@rocketmail.com for required information.
Posted on Apr 05, 2009
The internal flash on my canon eos 60d camera won't pop up
On the hot shoe when you fit a flashgun it pushes two tabs down to disengage the pop-up flash some times the tabs don't fully return after flashgun removal
Jan 17, 2016 | Canon EOS 60D Digital Camera
Use of Canon 60D's wireless function to control power on Canon 430EXII, being operated manually.
Your flash will fire optically. This is wireless but not radio.On the flashgun window move through the options until you see all of these in the window :- Flashing M, MZoom (24mm)
(the power output eg) 1/4
Flashgun icon CH1 Slave (blank)
The front panel should show a flashing red light. This means it is ready to receive the light signal from your onboard flash. From the camera menu select the in built flash control.
Set it to - Built-in flash - CustWireless
Flash mode - Manual flash
Wireless func - (single flashgun icon)
Channel- 1 ch
firing group - (flashgun icon)All
(flashgun icon) flashoutput - 1/64
selecting 1/64 should be sufficient to trigger the flash gun but not light the scene.
Manually pop up the onboard flash
In the view finder you'll see a number of green bars when half pressing the shutter and wait for them to go down to one which mean the camera and flashgun are communicating, fully press to take the shot and the flash (off camera) should fire.
Jun 26, 2017 | Canon EOS 60D Digital Camera
Can I used Nikon D90 with vivitar 636AF flash
You need a WEIN Safe Synch Hot shoe adapter first. The trigger voltage could possibly ruin the flash circuitry of the camera if not the camera as a whole. Even with the wein, you will not have iTTL nor TTL and can only be used in Auto or Manual Mode.
Dec 25, 2010 | Cameras
Hey guys. I use my old vivitar 728AFC flashgun on my canon 550d (T2i). the flash works but does not communicate fully with the camera, however my problem is; when set my camera ss higher than 1/200 it...
Hi, the flash in question will not work in TTL mode even though it has contacts on the bottom that may indicate that it could...... so it will work in auto or manual mode but not adjust itself. All adjustments will have to be made manually.
Sep 14, 2010 | Canon EOS 550D Rebel T2i Digital Camera
Does not have a flash shoe but has a red M snd a
The M is for flashbulbs, the X is for electronic flash. Sorry, but it won't sync with flash powder :-)
I don't see a manual for the FT, but I found manuals for the FTN and the FT2 at http://www.butkus.org/chinon/nikon.htm
Feb 18, 2010 | Nikon Nikomat FT 35mm SLR Camera
My flash won't charge. the yellow charge light won't go off when the camera is charged. The flash will pop open but won't flash. I have purchased and installed a new battery but it didn't solve the...
Either the internal thyristor charging circuit has failed or the flash capacitor is unserviceable.
Neither fault is worth repairing. Buy a small auto-exposure flashgun and use it in the hotshoe; they're dirt cheap and there are plenty of used ones for free if you ask on FreeCycle.
You'll need to go into the DSC-V1 menus to enable the hot shoe on the top plate of the camera and you'll find that even the smallest and least specified flashgun will give better results, but try to get one with at least two aperture settings within the range f2.8 to f8. Anything outside that range is useless to you as that's the entire aperture range on the DSC-V1. You'll also need to ensure that when taking photos, the camera is set to the same aperture as the flashgun. To do this set the camera mode switch to "A" for aperture priority mode and use the thumbwheel to select the correct aperture, the camera will choose the appropriate shutter speed. You can also use "M" for manual mode in which you set both the aperture and choose the shutter speed. At night, choose 1/60 but the actual exposure will be measured in the thousandths of seconds in which the flash is illuminated.
If you're rich or lucky you'll get a Sony HVL-F32X flashgun; it dwarfs the camera and is very powerful but everything is fully automatic with no manual overrides. For this flashgun, the hotshoe menu setting must be "OFF".
Nov 20, 2008 | Sony Cyber-Shot DSC-V1 Digital Camera
Flash Gun Broken can it be fixed
Buy distilled water.
Try to open the flash apart.
Pour distilled water to unit and blow dry or just set it near sunlight until dry.
atdlee@netzero.com
Jul 30, 2008 | Vivitar 283 Flash
Vivitar 3200 Flashgun and Canon EOS 400D
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Apr 13, 2008 | Cameras
Canon EOS 1000F in-built flash unit
Set camera body for Internal Flash for Pop-Up Flash.
Set camera body for External Flash for parked flash on Hot Shoe.
atdlee@netzero.com
Nov 08, 2007 | Canon EOS-3 35mm SLR Camera
Cameras Logo
932 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
