Question about Maytag 24 in. MDB9150A Built-in Dishwasher
CLEAN and LIGHT WASH lights blink
Any idea why the CLEAN and LIGHT WASH lights blink on the MAYTAG
MDB9150?
  • pfargot Sep 07, 2008
    Same problem.
  • Anonymous Mar 22, 2014
    dishwasher blinks a error code number 9 when machine done washing have any idea what it means?thanks
    Novelist:
  • 166 Answers
Peace,
Cut the power from the breaker source for 5 minutes. And it should reset the system!
Other wise you need hands on service
Posted on Sep 07, 2008
My Maytag MDB6160AWW finished its last cycle with a blinking "clean" light. I didn't think much of it. And somehow cleared the lights. When I filled it up and wanted to start a wash it will light up,
Blinking clean light is an error code does it blink 7 time pause then repeat that would be a heat circuit problem fast blinking a stuck key behind the lower panel should be a tech sheet explaining how to determine what the code is
Dec 24, 2014 | Maytag Dishwashers
Maytag dishwasher mdb7100aws is flashing clean-lightwash-heated dry
I have a Maytag MDB7100AWS which suddenly started blinking the following LEDs: Clean, Rinse Only, Regular Wash, Tough Scrub and Heated dry. Tried cycling the breaker, no help. Tried the key sequences in the troubleshooting sheet behind the kick panel, no help. Then happened to press the Drain/Off button twice. All LEDs went out and am now on my second successful load, fingers crossed. Suspect the control board got latched up somehow.
Jan 25, 2012 | Maytag Dishwashers
My clean and light wash light constantly blink, and nothing I do seems to help
try pushing the heated dry then sanitize buttons 4 times. one then the other in quick succesion. all lights should come on,, this is a test and will take about 8 min. let it go thru this and then try your washer. make sure you run hot water at your sink before you wash dishes in the future.
Jan 02, 2012 | Maytag MDB7100AWB Dishwasher
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
MDB9150 The Clean light is on
Bad computer board. You will need to replace it. You can go to repairclinic.com they will have the part you need and the intstructions on how to replace it will be with your order
May 18, 2009 | Dishwashers
Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Mar 26, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Control panel lights OK; Won't start into cycles
Hey, just had the same problem with my 9150. Moisture got into the electronic key pad. $300 to replace it. I was 5 months out of warranty.
I called 800-688-9900 and Maytag agreed to cover the part and we have to cover the labor. Not completely satisfied but a little bit helps.
Jan 09, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
403 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
