Question about Asko Washing Machines
It is not spining - Asko Washing Machines
  • zareh Aug 31, 2008
    hi there thanks for your help i took the back cover to check if the belt to spin the   drum is cut , but everything in place and good condition spin it with my hand and shake it a bit  just that if there is any sensor in it  .it will balance it self again . and there you go it is working   now.  thanks
     i hope  from my side able to explain what was wrong and it will be usefull for the   future problem     bye
  • 639 Answers
Friend,
ngfam1 At your service!
Can be the link from the transmission to the agitator or even a dead transmission!
I am not there for hands on inspection so you may need to go with service.
How old is the washer?
Here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
I hope you can utilize the good advice I so enjoy sharing with all the good people we talk to!
ngfam1
Bless You
Please give me a good rating before you sign off here at fixya.com
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Posted on Aug 31, 2008
Why Do Kids Need a Chiropractor?
all bodies are held upright by muscles pulling on various parts of the spine , hips and shoulders
\ if the spine gets out of alignment, these muscles work over time to pull it straight which results in headaches , muscle pain and other ailments
chiropractor moves and realigns the spine to reduce that muscle problem
growing skeletons need constant alignment as all the joints are soft and easily damaged it left unattended
Jul 19, 2016 | Cars & Trucks
Tip
What Does a Chiropractor Do?
Chiropracty is an increasingly popular way of treating muscular problems and injuries.Chiropractors generally focus on neuromuscular problems, using spine manipulation and adjustment in their treatment methods.Viewed by most as an alternative therapy, chiropractors consider the relationship between the spine and the nervous system.Chiropracty believes that by treating spinal issues, pressure can be reduced on neurological tissue thus creating broad health benefits.Chiropractors uses a method called chiropractic adjustment to make small but significant alterations to the positioning of the spine.Chiropracty is a very uninvasive treatment method that is usually very effective.
on Dec 16, 2013 | Medical
What is the spine corrector barrel?
The spine corrector utilized for individual needs, stretching, aligning and strengthening the spine. It also relieves stiffness of the shoulders and hips as well as relieving common backaches.
Aug 30, 2012 | Allegro Exercise & Fitness
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
Got a dc7600, need to add 2 more monitors, as video cards in my other computers will not fit (too large for slot)..if i can , i need a video card with two slots to attach both monitors or get 2 video...
Which part of the video-cards are "too large" -- the electronic circuitry, or just the "spine"?
If just the "spine" is too tall, then unscrew the spine from the card, and attach a shorter spine.
Or, if you are "brave", then run "*****" -- don't attach any "spine" to the video-card.
Just connect the VGA/DVI cable from the monitor directly to the video-card.
Aug 18, 2011 | HP Compaq dc7600 Small Form Factor PC...
The needle doesn't go up & down. Any suggestions? Thank you
Does the handwheel turn eazy or is it stiff. If it is stiff you need to take the top and bottom off and lubricate all moving parts. may take a bit of turning the handwheel and lubicating(it may tire you out). If the handwheel is not stiff I would check to see iff the motor is spining at all. If motor is not spining may be a bad footcontrol. If it is spining try cleaning the belt pullys and tighting the belt.
hope this helps
Mar 22, 2011 | Kenmore 15516 Mechanical Sewing Machine
Oreck won't pick up dirt.
Check the roller brush, dust channel and then the back spine tubes - two parts which also holds the cloth bag - which holds it at the bottom via a spring. Unhook this, and prise up the rubber rings that hide the push in locks. Push the locks in and the spines should separate.You may need to undo the power cord since it comes out the top near the handle at the bottom. Check both spines and remove clogs with a thin round stick. Put everything back together slowly and switch on.
Jan 12, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The starter makes a tik tik tiking sound
the seloind is gone or the battery is down
Jan 08, 2009 | 1998 Dodge Intrepid
Printing spine labels for books on hp laserjet 1020
convert the doc to a PDF so that the sizes and fonts save. That should fix your issue.
Jun 05, 2008 | HP LaserJet 1020 Printer
Washing Machines Logo
29 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
